Interior/Exterior Sparco Seat Help
You need one base/slider bracket per side. Outmotoring.com has them for $140/side. They allow fore-aft adjustment, and I think they're even adjustable for height. You can probably buy some fixed mounts for less if you don't need the adjustability.
Well...first off...what seats do you have? That determines if you have to hard mount them or you can use a slider system with it. My sliders and hardware for BOTH seats were like $300. But, I got my seats for $700 NEW. I gotta run my father-in-law to the airport but I will be back on. Hit me up or call me.
I'm sure you can get seats somewhere for 2600 a piece.
For what I want to do I'll probably end up paying far more than that. But I want to take some Sparcos and do some custom upustry stiching and some other custom add-ons so I know that'll be a big hit. Step one is save the money to where its not an issue, step two is pock which Sparco to order, then find a quality automoive unphoslterer and figure out what the end bill will be.
I know Sparcos aren't "cheap" seats, but subconsciously, I've always thought of them that way. I just figured out why - I can't hear "Sparco" without thinking of "Sparkomatic" car stereos.
(And if you've never owned Sparkomatic stereo equipment, consider yourself lucky. That and Kraco...)
Back in '03, my Torino set (I guess Torino-1 model) was about $900 and sliders/base totaled about $160. Yes, you'll want the sliders if you ever want anyone in the backseats. I also recalled the slider being hard to use unless someone sat on the seat and slid the seat... after uses, the slider loosened up and it's all good. The seats will sit about a little lower than the lowest setting on the stock seats.
After 56,000+ miles, the seat has held up. While the driver side seat's cushion isn't as 'full' as it use to be (ended up getting some kidney cushions), and there is some discoloration where the seatbelt rubs, I can't complain, money well spent.
EDIT: Another good thing w/ the Sparco base, is that it comes with the seatbelt bracket you'll need to mount the stock seatbelt buckle onto the new seat/base.
bADbOYbECK
41
10-16-2015 12:39 PM
F55/F56 Seat question (non-sport seats)
SeattleF56
09-03-2015 03:01 PM
