Interior/Exterior Steering wheel airbag help
Has anyone had any luck keeping airbag light off using the resistor trick on the steering wheel? I have searched but the only confirmed cases seem to involve the seat airbags. Also, on the steering wheel connector there are four pins, does this require two resistors? Thanks in advance for any help
I went ahead with mine because I was in the middle of the install when I asked and I needed to get to work the next day. I tried to do the resistor trick on both sets of leads. No luck with that, the light turned on anyway. Hopefully someone else will be able to provide more info if they have succeded.
07-16-2020 12:54 PM
Manny_cooper
09-10-2015 11:09 AM
trw92a
08-26-2015 01:47 PM
