Interior/Exterior UV LEDs...anyone played with them?
I was wondering if anyone has ever used UV LEDs. I wanted to use just a few to illuminate a switch panel with blacklight sensitive logos on them. Basically, I just want the LED's on when the speedo/dash lights are on. Does this sound like it might work? Any feedback? Maybe it just sounds lame.... I don't think so, let me know what you think.
Matt
Matt
It will work...
but have you thought this through... You'll be shining UV at whatever they point at, and this can bleach stuff over time. I think you may do better just using DayGlo paints to get that look without the LEDs.
I haven't used any for a while though. And they just emit one wavelength, as opposed to the broad band radiation in sunlight. I don't know how that will effect the game.
In general, you only want to use a UV lightsource when there is a UV absorber between you and the source. You can't see the UV rays, and they can cook you.
Matt
Matt
Hmmmmm..... Those all seem like valid points. I won't deny that some version or another of those concerns crossed my mind. I quickly dismissed them and thought, "Ahhh, there can't be THAT much UV." But I could very well be wrong.
Part of what I wanted to accomplish was a switch that had an illuminated icon on it at night, even when the switch was off. There are a ton of switches that light up when the switch is "ON." I want to be able to see which switch is which when they're off and it's dark. Any other ideas?????
Use a double pull double throw switch...
Tuls, there are a lot of LEDs out, and I'm sure you can get brighter if you like. But they get expensive fast for UV, and some can emmit enought to be dangerous.
Matt
I was thinking about this more...
Matt
Here you all go!
http://www.nichia.com/product/led-lamp-uv.html Now you can get a 1/2 AMP UV LED. Can we say tanning bed!
Matt
Matt
the acual UV purple (black light) ones... suck... like a real black light they don't really emit any light...
as for the white ones.... etc... they are awsome... super clean and bright... I have them all over in side and out... they rock...oh yeah I have blue ones inside... and white ones for the map lights... again... awsome...
http://www.autolumination.com/194.htm
If you really want to go nuts, use these UV LED strips... Some combine them with a colored strip or with tactically placed individual LEDs so you have some visible light.
http://www.oznium.com/led-flex-strips
IQRaceworks
53
06-28-2024 07:29 AM
Navigation & Audio USB stick keeps repeating same folder
Wombat Pie
Navigation/Audio
10-05-2015 08:00 PM
dutchhome
09-30-2015 07:17 AM
