Interior/Exterior Paulo Uber Stubby Antenna Issues
Old 04-04-2007, 10:49 AM
gnatster's Avatar
gnatster
gnatster is offline
Originally Posted by Dr Obnxs
whatever happened to bent hangar wire? Want a stubby, just cut it shorter...
Matt
You forgot the tin foil...
  #77
Old 04-04-2007, 10:51 AM
SayGoodbye's Avatar
SayGoodbye
SayGoodbye is offline
Exactly! Twist it up, paint it black and get vendor status!
  #78
Old 04-04-2007, 11:21 AM
ImagoX's Avatar
ImagoX
ImagoX is offline
To all of you pushing the Honda S2000 stubby. Thanks, but that is not the look I desired, if it was I would have gone that route. I have subsequently found that even using no antenna I can still receive the single NPR station I listen to on occasion. I will obtain a bolt of the proper thread and diameter to fill the hole. I'll fit it with an O-Ring to seal out moisture and dirt, then grind the head down as much as I can to achieve a flat look and paint it black myself.
Um... I'm "pushing" nothing - I just thought I'd mention that I was personally happy with that solution. Of course, I wouldn't have ordered such an expensive antenna as the PU in the first place... Glad you have a solution that will work for you (although I'm still rooting for you to get a refund).
  #79
Old 04-04-2007, 11:39 AM
Edge's Avatar
Edge
Edge is offline
AdMINIstrator
Originally Posted by PGT
check it now and get back to me
Hmmm... it never used to allow that. Some options must have changed. I'll look into that.
  #80
Old 04-04-2007, 11:46 AM
PGT's Avatar
PGT
PGT is offline
see? I don't make this **** up! as a mod on other boards, I'm quite familiar with vBulletin
  #81
Old 04-04-2007, 01:40 PM
Dr Obnxs's Avatar
Dr Obnxs
Dr Obnxs is offline
Ya want a good coating?
bead blast and powder coat to the color of your choice......
Matt
  #82
Old 04-04-2007, 01:49 PM
Squirlz's Avatar
Squirlz
Squirlz is offline
As long as this thread is still going on, can someone tell me the thread size for the antennae stud? Thanks.
  #83
Old 04-05-2007, 09:26 AM
Edge's Avatar
Edge
Edge is offline
AdMINIstrator
Try it now, it should be fixed. (of course, make sure you're beyond the 2-minute grace period)
  #84
Old 04-05-2007, 10:40 AM
PGT's Avatar
PGT
PGT is offline
1:40pm - now 11:04
  #85
Old 04-05-2007, 01:39 PM
blumini's Avatar
blumini
blumini is offline
1500+ Views, 85+ Replies & 4 Pages for an ANTENNA!!!
Here's my solution...
  #86
Old 04-05-2007, 03:39 PM
PGT's Avatar
PGT
PGT is offline
is that a monkey's biker helmet?
  #87
Old 04-05-2007, 05:39 PM
minimusprime's Avatar
minimusprime
minimusprime is offline
lol good one.
  #88
Old 04-05-2007, 06:11 PM
MiniSuperCooper's Avatar
MiniSuperCooper
MiniSuperCooper is offline
I'm definitely no expert in the field of anodization...in fact, I had never heard of it before six months ago. Now I have a couple of things that are anodized. They both look more like the black antenna with chips...texture and everything. My anodized things chip easily too. I used a black permanent marker to hide the chips. I'm not saying that the second stubby you received is definitely anodized, but I think it's highly likely that it is.
  #89
Old 04-05-2007, 08:39 PM
rkw's Avatar
rkw
rkw is offline
To my eyes, the antenna on the left looks obviously painted and the one on the right looks anodized. What are the two things you have that you believe to be anodized?
Anodization forms a layer so thin that it does not create its own texture like paint does. I'm trying to think of some common anodized objects that might be familiar to most people. Maglite metal flashlights have an anodized finish, as does the new (2nd gen) iPod Nano. Maybe others could think of examples that are even more common.
  #90
Old 04-05-2007, 09:51 PM
MiniSuperCooper
My Alta stubby antenna and the M7 strut tower brace. My stubby doesn't really look like either of PU's on this thread. It's just black...no fading at all. My M7 STB, on the other hand, looks a lot like the black PU antenna (the one with chips). The M7 STB has a rough texture, and it also gets chips like that too (it actually came with some chips)...a little permanent marker (as long as it's a small area) and you can't really tell though. Neither of these are like maglites and other anodized things you might buy at a store. Those things look dyed...you can almost see the metal through the dye...if that makes sense. These two products that I own don't really look like that at all to me. Of course, I'm no expert...and I haven't seen his antenna in person to compare it to the M7 STB.
  #91
Old 04-06-2007, 12:42 AM
SayGoodbye's Avatar
SayGoodbye
  #92
Old 04-06-2007, 05:21 AM
gnatster's Avatar
gnatster
gnatster is offline
Update....
I received an unsolicited message from a representative of Mini Madness to call them on their toll free number to discuss the matter. I called and spoke to George who did confirm there was a run of painted antennas. George went on to inform me a new run of anodized antennas is in the works and one will be sent to me once Mini Madness has them in hand.
I did ask if they would want me to send back others and was told that is not required. Once received I will update again. [FONT=&quot][/FONT]
  #93
Old 04-17-2007, 05:18 AM
obehave's Avatar
obehave
obehave is offline
Snip.... I will obtain a bolt of the proper thread and diameter to fill the hole. I'll fit it with an O-Ring to seal out moisture and dirt, then grind the head down as much as I can to achieve a flat look and paint it black myself.
....snip
Why not just use a set screw? Then use a plastic body panel plug to seal the top off nice and smooth.
  #94
Old 04-17-2007, 05:21 AM
obehave's Avatar
obehave
obehave is offline
Looks like a biker helmet from the 60's.
  #95
Old 04-17-2007, 05:29 AM
PGT's Avatar
PGT
PGT is offline
WTLW
  #96
Old 05-01-2007, 01:19 PM
gnatster's Avatar
gnatster
gnatster is offline
Update...
After speaking to George at Mini Madness it was stated that new properly anodized units were on the way. That was about 3 weeks ago. As of today still nothing. Will update again in a few weeks if there is news or not.
  #97
Old 05-02-2007, 06:17 AM
Aeromax's Avatar
Aeromax
Aeromax is offline
I've wondered... what did "Sir Patrick" do to become knighted?
  #98
Old 05-02-2007, 07:29 AM
Loony2N's Avatar
Loony2N
Loony2N is offline
Maybe he sleighed the Dragon.
  #99
Old 05-02-2007, 09:35 AM
Passat774's Avatar
Passat774
Passat774 is offline
he bought a Mini
  #100
Old 05-02-2007, 11:46 AM
Aeromax's Avatar
Aeromax
Aeromax is offline
Is that all it takes these days?
I'd love to be Sir Maxwell, in that case.
Quick Reply: Interior/Exterior Paulo Uber Stubby Antenna Issues
