Interior/Exterior Head Unit Install
Have a look here:
http://gpmini.net/wp/2007/01/afterma...tereos_in_gps/
or maybe here is better:
http://www.gbmini.net/wp/2005/04/new..._installation/
Did you buy a wiring harness? (you'll need to seach the navigation audio section if you haven't and need to find it).
Is this your first time installing an aftermarket deck? (if yes, you'll need to pick up some supplies like a wire crimper and wire taps)
When you buy a wiring harness you just need to match up the wire color. You'll also need to wire Pin # 13 on the factor harness (White wire) to a switched 12V supply or else you'll loose your AM.
Also did you search the naviation audio section yet? The 2nd post in the sticky section gives you everything you need.
https://www.northamericanmotoring.co...ad.php?t=84200
Navigation & Audio Impedance of Stock Under-Seat Speakers
jnrjr79
Navigation/Audio
18
09-18-2015 05:51 AM
Navigation & Audio help identifying a couple wires
yashmack
08-15-2015 03:11 PM
