JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW my new 2012 jcw coupe 250hp
Old 02-17-2012 | 11:25 AM
acejcw's Avatar
acejcw
What's the best and safest way to get to 240-250 horsepower. Only had the car few days but this is my second mini I had a bunch of alta stuff on last one.
Old 02-17-2012 | 01:27 PM
SooperCuperErik's Avatar
SooperCuperErik
Bolt ons wont get you there.
Gonna have to wait for a tune, or send out your ECU to be tuned.
Please search
Old 02-17-2012 | 01:50 PM
Cred's Avatar
Cred
When you find out tell me!
acejcw's Avatar
acejcw
How about the altar access port?
Old 02-17-2012 | 08:55 PM
walk0080's Avatar
walk0080
JCW Coupe has the same engine as the hatch. Tunes are available although I don't know how "safe" they are.
Old 02-17-2012 | 10:57 PM
PatM's Avatar
PatM
I don't think that is true. The JCW Coupe has the older style engine without the valvetronic valve train, N14 The hatch has the new N18 valvetronic motor. They are not the same.
In my driving of the two cars the Coupe S has the newer motor and the JCW that I test drove and my car do not have the fully variable valve management.
Old 02-17-2012 | 11:35 PM
bluefox280's Avatar
bluefox280
Originally Posted by PatM
I don't think that is true. The JCW Coupe has the older style engine without the valvetronic valve train, N14.
Correct, the 2012 factory JCW variants still use the N14 and therefore still can be ECU programmed with ease.
acejcw, you won't be at 250hp with these three modifications, but they are the most bang for buck in terms of power for the N14: ECU programming, intercooler, and exhaust downpipe.
- Erik
Old 02-18-2012 | 01:38 AM
walk0080's Avatar
walk0080
Yes that is what I said - I drive a JCW hatch... perhaps it wasn't clear and this is what I meant
"JCW Coupe has same engine as the JCW Hatch (N14). Tunes are available although I don't know how "safe" they are."
Old 02-18-2012 | 03:24 AM
Jack$0n's Avatar
Jack$0n
IMO its always better (for power) to get the intercooler, and exhaust downpipe.... than take your MINI to someone like Way @ Way Motor Works to have a custom tune done just for your MINI. That is the safest way I know.
I do have a Alta Access Port... and love it for the power... BUT like many say.... it is not a custom built tune for me... so I DONT know how safe it is. So I just use the Tune on days I want the extra power. Good news is that I can swap Tunes in less than a minute.
I wish I had spent the money on a custom tune. I will do it eventually but waiting to get all part on my MINI first.
I would also add a Forge BOV (blow off valve) while your at it... and the NM Torque bushing. If you have the dough. $$
Old 02-18-2012 | 03:26 AM
Jack$0n's Avatar
Jack$0n
The first and best mod i would recommend is a rear sway bar!!!! I'm sure you already know that.... just my 2 cents
Old 02-18-2012 | 06:16 AM
anitan1's Avatar
anitan1
Jackson, we've talked about this before but, what's the purpose of the Blow Off Valve?
Old 02-18-2012 | 06:22 AM
acejcw's Avatar
acejcw
What is the difference between the new and the old engine I hope I didn't make a mistake by not waiting.
Old 02-18-2012 | 06:51 AM
orangecrush's Avatar
orangecrush
IMO, nothing but to make more noise....
Supposedly if you get an aftermarket BOV, it will open quicker to release the pressure faster.
I HIGHLY doubt anyone can install one, do a dyno or 1/4 mile time trial and see any difference. IMO, it’s there to make more noise.
My .02 worth....
Mark
Old 02-18-2012 | 09:58 AM
HorseWithNoName's Avatar
HorseWithNoName
Please search
Who would you send the ECU to on a N18?
Old 02-18-2012 | 02:17 PM
automan21's Avatar
automan21
Originally Posted by twincoopers
who would you send the ecu to on a n18?
+1^^^
Old 02-18-2012 | 02:19 PM
acejcw's Avatar
acejcw
So what's the difference between the to motors
Old 02-18-2012 | 07:57 PM
Jack$0n's Avatar
Jack$0n
I put a Forge BOV on .... and noticed a difference. I did not hear any noise difference at first. I only noticed the noise or a noise (not 100% sure it's all from the BOV) after I installed a aftermarket intake. Now I have that sucking sound.
But to answer your question.... I noticed the response time when I hit the gas the power is there and stays there a lot better. Especially between gear shifts.
The small little lag the stock BOV disappears. Mainly noticed it at lower to mid rpms .... at higher rpms (> than say 4000) you probably won't see the difference.
PLEASE NOTE!!! I did install the heavier stiffer spring (yellow) which gives me a more consistant boost and I have seen my boost with the ALTA Tune stage 1 go up to 21-23. Without tune.... usually tops out around 15.
This is of course just my opinion. I think Way Motor Works or a pro would be able to give you a better answer....
Do I think it's worth it..... HELL Yeah! But of course I ONLY recommend the FORGE BOV with Yellow or stiffer spring. With a good custom tune and intercooler and stage 2 or higher.. you can get even a stiffer spring. If I remember right..... there are 2 more springs stiffer yet.
Old 02-19-2012 | 12:05 AM
Jolio's Avatar
Jolio
Jackson - you end up uninstalling you OCC? Don't see it your sig anymore.
Old 02-19-2012 | 04:47 AM
Jack$0n's Avatar
Jack$0n
Yes sir!
From Way @ Way Motor Works ..... recommendation... I uninstalled the OCC. I still have it if you want it? I only used it for maybe a month. Clean as a whistle.
Way stated to me that he never installs them ....even on his race cars. I wish that there was more data to support the need for one.
I do always use SeaFoam on every oil Change. Also don't know if this actually helps ... but for a few bucks .... it can't be hurt.
(I know there is a huge debate on this topic , but I figure I would rather be an optimist about it)
I do get a small boost from the SeaFoam right after using it.... but I don't think it stays. I just hope it's helping keep the motor a little cleaner.
Old 02-19-2012 | 05:04 AM
walk0080's Avatar
walk0080
Check MotoringFile or search the forum for more details.
N18 basically has full ValveTronic which gives more HP and better efficiency... However there is no JCW for sale (yet) with newer N18 engine and JCW factory bits. Maybe a year, maybe longer, before you see the newer engine on a JCW. Keep an eye on MotoringFile but by the sounds of it MINI is working on it.
I wouldn't worry too much about not having the N18 engine.
Old 02-19-2012 | 06:23 AM
orangecrush
I think that the increase is so minimal, there’s no way you can feel it by seat of your pants. I doubt you could see it on the dyno. (this is assuming that the factory BOV is in working condition)
I think it’s like exhaust, the sound we hear makes the car seem faster.
Check out this video.
As you can see, they all have the same results. In the end, the factory BOV did leak a bit but it was also 10 years old. I’ll bet if they had installed a new OEM valve, it would have produced the same results.
Old 02-20-2012 | 06:25 AM
yetti96's Avatar
yetti96
Yes sir!
So is it for sale then?
Old 02-22-2012 | 03:24 AM
johnf36's Avatar
johnf36
Acejcw;
Cornelis Hollander is running a full stage 3 Alta / Access Port on his JCWcoupe with no problems, You can find him here https://www.facebook.com/groups/211254292274789/
Old 02-24-2012 | 06:27 AM
quality_sound's Avatar
quality_sound
If his isn't, mine is. I have ZERO room to install it without changing the intake and I'm in no hurry to do that.
Old 02-24-2012 | 06:50 AM
Keano's Avatar
Keano
A JCW should see 250hp from a map quite easily I would have though - JCWs over here that have the N14 engine have been over 250hp with just a map... most seem to be around 230hp when stock...
Or do you mean 250hp at the wheels ??
