JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW JCW Carbon Fiber E-Brake Install Help
Old 08-31-2013 | 05:51 PM
cactusjk's Avatar
cactusjk
I have searched and searched and am reaching out for someone who can point me to the right threads.
I have a 2013 R56 JCW and am replacing the e-brake handle with the JCW CF part:
Some say you need to glue the handle. No glue comes with it. Advice?
What is the easiest way to remove the original handle?
Any additional recommendations on removing the boot and zip tying the boot to the new handle?
Old 09-01-2013 | 07:59 AM
cactusjk's Avatar
cactusjk
I guess glue is the answer. Any recommendations of the best type of glue/silicon?
I do not want to tape it due to heat.
Old 09-02-2013 | 09:02 AM
e46jb's Avatar
e46jb
MINI has a special glue that you will need to use. It allows the e-brake handle to be removed in the future if you don't want to reverse the installation
Old 09-02-2013 | 09:08 AM
cactusjk's Avatar
cactusjk
Any idea what that special glue is?
Old 09-02-2013 | 01:11 PM
e46jb's Avatar
e46jb
If I recall correctly, it is a form of loc-tite. I can see if I still have the glue from when I installed mine.
Old 09-02-2013 | 01:18 PM
akng's Avatar
akng
if i recall correctly, it is a form of loc-tite. I can see if i still have the glue from when i installed mine.
81229407394
Old 09-02-2013 | 04:38 PM
cactusjk's Avatar
cactusjk
I was thinking about using E6000 adhesive as recommended on another thread.
Old 09-02-2013 | 07:22 PM
llewellyn's Avatar
llewellyn
I found a thread online, and what a lot of people did (Myself included) was take the old handbrake lever off (Pull straight out), take tape, (either electrical or masking tape) and wrap at least one tight wrap around the metal handle to slightly build up the diameter. Then take your JCW handbrake and push / twist it on. I had to play around with it, I think I ended up using masking tape because the electrical tape was too sticky and I wasn't able to push the handle on. I know it sounds kind of mickey mouse, but it works really well - My handle is solid, I've had it on for a couple months now and it won't budge, but if I ever want to take it back off for any reason, I know it's possible. Hope this helps!
Old 09-08-2013 | 07:43 AM
cactusjk's Avatar
cactusjk
Even the Mini dealer recommends taping so you can later remove if necessary. They use a felt backed foam tape.
Old 09-08-2013 | 11:04 AM
peterpan101's Avatar
peterpan101
yep, tape is the way to go
minimofo
Factory JCW Talk (2009+)
130
10-14-2016 06:14 AM
Indimanic
03-04-2016 11:20 AM
marendt428
02-25-2016 07:13 AM
marendt428
08-09-2015 06:54 PM
OutMotoring
08-06-2015 09:32 AM
Quick Reply: JCW JCW Carbon Fiber E-Brake Install Help
