JCW JCW Aftermarket Wheels
Old 04-16-2021, 03:37 PM
checopr2's Avatar
checopr2
checopr2 is offline
I have 225x40x18 no issues! Lowered with H&R springs
jeeper02 (08-05-2021)
  #577
Old 04-17-2021, 04:57 AM
Ruben's Avatar
Ruben
Ruben is offline
Thx for the reply!
My tire fitter tells me i should mount 22/40/18 on 8.0. So no one has rubbing issues with 225/40?
  #578
Old 04-17-2021, 06:57 AM
checopr2's Avatar
checopr2
checopr2 is offline
No issues my friend! I was looking everywhere for specs and I just went for it... it worked with no issues.
  #579
Old 04-19-2021, 03:03 PM
Robby Kalna's Avatar
Robby Kalna
Robby Kalna is offline
Did you have to use spacers? I ended up needing 15mm spacers up front on my current wheel setup and am thinking of getting some OZs instead but want to minimize spacers if possible.
Thanks!
  #580
Old 04-19-2021, 08:10 PM
checopr2's Avatar
checopr2
checopr2 is offline
No spacers needed with this wheel set up! Everything should fit like a glove!
  #581
Old 04-20-2021, 01:05 PM
J_L's Avatar
J_L
J_L is offline
@checopr2 , what is the offset?
  #582
Old 04-20-2021, 01:09 PM
checopr2's Avatar
checopr2
checopr2 is offline
18x8 et45
J_L (08-03-2021)
  #583
Old 08-03-2021, 01:42 AM
SimpleMini's Avatar
SimpleMini
SimpleMini is offline
Got an extra set of wheels over the weekend.
BBS RE-V7 / 18" 8J ET45 / Running on 215/40/18 Bridgestone RE-71RS / No Spacers and clears the JCW brakes
At 17.63 lbs per wheel, I am a happy man.
The following 7 users liked this post by SimpleMini:
///Matthew (08-03-2021), bluonyx (06-17-2023), Clutch Wotan (10-28-2021), F56-JCDub (08-03-2021), Goin2dirt (08-03-2021), jeeper02 (08-05-2021), J_L (08-03-2021) and 2 others liked this post. (Show less...)
  #584
Old 08-03-2021, 04:03 AM
Goin2dirt's Avatar
Goin2dirt
Goin2dirt is offline
So nice. I want to upgrade soon the wheels and tires on my 22 F57.
  #585
Old 08-03-2021, 04:10 AM
F56-JCDub's Avatar
F56-JCDub
F56-JCDub is offline
That's awesome that you didn't need spacers. How much clearance do the front brake calipers have?
Also, do you have any suspension mods? Looks lowered...
  #586
Old 08-03-2021, 09:44 PM
Clutch Wotan's Avatar
Clutch Wotan
Clutch Wotan is offline
  #587
Old 08-03-2021, 10:34 PM
SimpleMini's Avatar
SimpleMini
​​​​​​​3mm clearance for the brakes.
Suspension mods will be KWV3, NM rear sways and end links, NM Rear Control arms, Craven speed big pairs, NM Front Strut Bar, Powerflex PP suspension mount throughout.
F56-JCDub (08-04-2021)
  #588
Old 08-04-2021, 03:52 AM
F56-JCDub's Avatar
F56-JCDub
Suspension mods will be KWV3, NM rear sways, and end links, NM Rear Control arms, Craven speed big pairs, NM Front Strut Bar, Powerflex PP suspension mount throughout.
​​​​​​​Very nice indeed!
  #589
Old 08-08-2021, 10:13 AM
Masada's Avatar
Masada
Masada is offline
I ordered these for my F54 JCW but it will be a few months before they arrive. I can't wait to see how they look when mounted.
J_L (08-08-2021)
  #590
Old 08-08-2021, 10:25 AM
Darbys2019MiniJCW's Avatar
Darbys2019MiniJCW
Darbys2019MiniJCW is offline
J_L (08-08-2021)
  #591
Old 08-09-2021, 06:54 AM
F56-JCDub's Avatar
F56-JCDub
Does anyone have wheel hub and brake caliper profile measurements or CAD drawings? This coupled with wheel manufacturer profile measurements would make measuring clearances way easier.
  #592
Old 10-21-2021, 07:21 PM
Masada's Avatar
Masada
Masada is offline
I finally got the wheels last Sunday and mounted rubber today. Advan RS-DF Progressive, T-6061 aluminum and fully forged. At 18lbs for a 19 inch wheel, it should be a noticeable difference. These wheels can accomodate brake discs up to 400mm and will easily clear the calipers which is what I needed. They are 19x8j, et48...I am going to run 5mm spacers up front and 10 in the rear...
  #593
Old 10-27-2021, 06:46 PM
shadow993's Avatar
shadow993
shadow993 is offline
Got these for the track... on the cheap. Weighed 6.5lbs less.
Stock track 17" 215/40/17 with Falken 615 weighed 47lbs
These with hankook 205/45/17 run flats 40.5lbs
https://www.ebay.com/itm/2PCS-17-17X...-127632-2357-0
  #594
Old 10-28-2021, 06:25 AM
Clutch Wotan
how did you fix the bore ?
  #595
Old 10-28-2021, 05:55 PM
Masada's Avatar
Masada
Masada is offline
You would need a hubcentric ring and you are golden.
  #596
Old 10-28-2021, 09:11 PM
shadow993's Avatar
shadow993
eBay ... $4
https://www.ebay.com/itm/SET-OF-4-HU...-127632-2357-0
  #597
Old 01-04-2022, 07:23 AM
Bruce R's Avatar
Bruce R
Bruce R is offline
@shadow993 Can you share pictures with these on the car? I would like to see the front caliper clearance as well as fitment under wheel well. What year JCW do you have?
  #598
Old 01-04-2022, 08:36 PM
Bruce R's Avatar
Bruce R
Bruce R is offline
+1 and they are one of the few " * Forged Aluminum Wheel Set * " from MINI.
@ECSTuning , your site says these require a spacer to clear the brakes, but https://www.northamericanmotoring.co...ml#post4099094 this thread says they clear the brakes (implies without spacers). Can you please confirm which is the case?
Sorry, for the cross spoke wheels: ECS Part # ES#2749156
  #599
Old 01-05-2022, 07:57 AM
ECSTuning is online now
Received 2,100 Likes on 1,873 Posts
Hello
On this one MINI made a set of JCW wheels for the BBK (Factory JCW Big Brake kit) and a Set for normal brakes. One says JCW BBK and ones say just JCW.
It does not happen also, my guess is the JCW brakes came out in development after MINI already had the wheels casted from Ronal who is the OEM contract on most MINI wheels right now.
https://www.ecstuning.com/Search/Sit.../506_MINI_JCW/
  #600
Old 01-05-2022, 09:37 AM
Bruce R's Avatar
Bruce R
Bruce R is offline
@ECSTuning Thank you for the enlightenment on this. That makes sense.
ECSTuning (01-05-2022)
Quick Reply: JCW JCW Aftermarket Wheels
