FS:: 2005 JCW Cooper S better than New
Year: 2005
Model: Hardtop
Price: $13000
Mileage: 77000
Color: Dark Silver
Private or Dealer Listing: Dealer Listing
Location (Region): SouthEast
This is a almost perfect 2005 MINI Cooper S that has the original dealer installed John Cooper Works kit. That included the JCW cylinder head, supercharger, airbox, 380cc injectors, exhaust, and ECU programming.
In the last 2 years the owner went through it and repaired, replaced, or upgraded everything he could.
Upgrades include: OVER $7000 not including labor
Custom TSW KW Variant 2 Coilovers $1470
Vorshlag Camber plates $439
Front H&R Sway Bar $270
Rear Hsport Comp Sway Bar $249
Rear Hsport lower control arms $249
Front R56 S calipers (same as JCW) $500
Stainless Steel Brake lines $99
17% WMW supercharger pulley $179 kit
ATI Crankshaft damper pulley with seal $370
Forge Aluminum Coolant Tank $234
Way Motor Works Strut Brace $200
New Goodyear Eagle tires
Sony Stereo and all speakers upgraded
Upgraded Speakers and Amp
Powerflex Front Control Arm Bushings $87
Quaife Limited Slip Differential $1005
Valeo Clutch and Flywheel Conversion $511.50
screamin Demon coil pack $90
WMW plug wires $59
TSW short aluminum jack points $99
Redline MTL trans fluid $28
Rennline pedal set
Motul Brake fluid
New Water pump and supercharger service $550
New clutch slave cyl $45
Chrome PS tank cover
Chrome brake fluid cap ring
New driver CV axle
5mm WMW front wheel spacers $30
dynamat throughout
Factory options:
Rare Chrono Package
Cold Weather Package
Front Fog lights
Auto A/C
Rain Sensing Wipers
Rear Park Distance Control
Xenon Headlights
Tan Leather Seats
6spd Manual Transmission
2pc BBS Webspoke wheels
If you have been wanting one of the iconic R53 Supercharged MINIs you have likely looked around and to find a decent car it's getting harder and harder. Then when you do it's likely missing some of the options you want or a ton of miles. Then you will likely find it needs normal maint items like bushings and expensive oil leaks fixed. This car doesn't need any of those maint items. It has been inspected by Way Motor Works in Atlanta Ga. The car has NO oil leaks. Supercharger was serviced with new water pump installed. Bushings replaced and upgraded with the powerflex bushings. No leaking power steering lines. It appears that the power steering pump and fan where replaced at some point. Also many of the gaskets replaced and WMW has thousands of $$ in receipts the customer bought parts for this car from.
These things I know were done by the owner:
Front crank seal replaced.
Crankshaft sensor seal replaced
Rear main seal
Clutch throw out bearing guide tube with clutch job
new clutch slave cylinder
trans input shaft seal
RedMiniBirmingham
09-22-2007 05:49 AM
seigmann
29
05-09-2007 07:03 AM
