Navigation & Audio DIY Garmin Nuvi GPS Mount
I made a GPS mount from a wire coat hanger. I wrote up instructions with photos here:
http://www.miniacal.com/garmin_mount/
It hooks into the vent.
There are some more pics at the link above.
Made another DIY Garmin Mount. Made from Aluminum, base is 2.717 diameter with a 1.5" stem thats roughly 1/2 diameter. Cut off the 17mm ball on the Garmin suction mount and used epoxy to glue onto the end of the 1/2 diameter stem. Drilled a hole thru the base to be able to use the charging cord. Will hard wire to the fuse box. Here are some pics.
Navigation & Audio HK Replacement With New Components
Filmy
15
06-06-2023 06:27 AM
patsum
26
05-29-2021 06:29 PM
09-04-2015 02:34 PM
