Navigation & Audio Aux input - only left side is audible?!?!
i installed an aux kit into my 03 hk mcs; i purchased a used 05 oem deck that plays mp3's. the first aux kit only had sound coming from the driver's side, nothing from the passenger's side. i got a second kit and tested it before i installed it. same outcome. i checked the pins and they all seem in good condition. the cd player and radio work fine, just the aux is screwy! i made sure i had stereo plugs. i'm using my sony ericcsson w580i phone as an mp3 player. someone please help! please please please thank you!
I haven't heard of a ground loop problem causing one side to drop out. A ground loop isolator usually fixes a problem where the head unit can't detect that aux is available, and aux stops showing up as a selection. It can happen when the player is connected to both aux and power (cigarette lighter) at the same time.
You've done just about everything I would have done. It would be a bummer if the fault is in the head unit.
Hmmm... obviously it was the old head unit. You know come to think of it, I had a similar problem on my 03 MC where the Aux In kept going in and out. Turned out it had just come loose a little bit where I plugged it into the head unit. Not sure if you just bought a new head unit already or if you're just borrowing one or what's up. But for future reference for you or anyone else, I'd check that first next time around.
07-16-2020 12:54 PM
cm.d
08-19-2015 08:51 AM
