Navigation & Audio How do I change my turn signals to blink 3 times?
It's currently programmed for one blink. I see settings for wiper frequency, miles vs kilometers, time, date, etc. But I don't see a place in my settings where I can change the turn signal frequency. Can someone tell me where I can find it?
The instructions are in your owner's manual but here is the procedure to change it.Keep in mind I took this from a pdf. so I hope this helps some.
2. Briefly press the button in the turn indicator lever repeatedly until "SET/INFO" is displayed.
3X Triple turn signal.
Press the lever as far as the resistance point.
Turn signal flashes once.
You can set whether the turn signal is to flash once or three times.
1. Switch on the ignition, refer to page 35.
3. Press and hold the button until the display changes.
4. Briefly press the button repeatedly until the symbol and "SET" are displayed.
5. Press and hold the button until the display changes.
6. Briefly press the button repeatedly until the display shows the illustrated symbol, arrow.
7. Press and hold the button until the display changes.
8. Briefly press the button to select:
1X Brief indication of turn.
Triple turn signal.
9.Press and hold the button until the display changes. The setting is stored.
As others have said...check the instructions in the manual. They are right, although they appear quite confusing at first. I have to pull my manual out everytime I need to reset them for some reason, a fact that I am in no way ashamed about!!! There is very little on this car (that I don't access regularly) that I expect to remember.
12-23-2015 10:36 AM
dscott90000
08-21-2015 07:07 PM
nismo4life
08-05-2015 08:31 AM
