Navigation & Audio Back up camera install wiring help!
I recently purchased a GPS unit (Nextar) that also has a wireless backup camera. I can't seem to follow the instructions for the back-up camera. Would any of you be able to walk me through the wiring process? It's likely pretty simply but I really have no experience in this area (electrical wiring, etc.).
I'm trying to wire the camera to the reverse lights. The instructions said I could either use a "Scotch-Lok OR wire them directly to the reverse circuit by stripping the reverse light wires then twisting the camera wires to the exposed reverse light wires. Once connected, wrap with electrical tape." ??
Any one with a step by step instruction for the above?
The camera is a license plate mount and I'm not exactly sure I want to drill a hole in my car. Looking at one of the other threads I guess I could hook it up beside the hatch handle in place of one of the hatch lights? BUt, I'm also not sure I want to lose one of my lights. If I did decide to drill a small hole should I put some paint or something in the hole to prevent rust? Also, I think I'd need some sort of rubber insert to protect the wire from the sharp metal? Thoughts??
Thanks in adavance
Thanks in adavance
Scraping the wire is more prone to causing breakage, and unless you solder will eventually oxidize and loose connection. A quick splice like rkw mentions is more reliable if done properly. Most important is do not use these in a location subject to water. Electrical tape detoriates into a sappy mess after a short time. I only use heat shrink tubing on my cars.
function popGlossary() { var window1 = window.open ("Glossary.html", "window1", "height=500,width=400,scrollbars=yes,toolbar=no,me nubar=no,location=no,directories=no,resizeable=yes "); window1.focus(); } function popAvail(MfrCode, PartNum, MfrName, Description, Price) { var window2 = window.open ("StoreAvailability.aspx?mfrcode=" + escape(MfrCode) + "&mfrpartnumber=" + escape(PartNum) , "window2", "height=500,width=621,scrollbars=yes,toolbar=no,me nubar=no,location=no,directories=no,resizeable=yes "); window2.focus(); } function popGuide(MfrCode, PartNum) { var window3 = window.open ("ProductGuide.aspx?mfrcode=" + escape(MfrCode) + "&mfrpartnumber=" + escape(PartNum) , "window3", "height=500,width=583,scrollbars=yes,toolbar=no,me nubar=no,location=no,directories=no,resizeable=yes "); window3.focus(); } Dorman Quick Splice Terminals: Conduct-Tite!(R); Solderless; Blue; 18-14 Gauge; 7 Per PackPart Number: 85464[SIZE=1](click image for full-size view)[/SIZE]PricingOur Price:$2.99 Availability
Thanks! I just picked up a few Scotch-Lok's at a local hardware store. I also found a way to mount the camera without having to make any new holes or remove any of the exhisting plate lights.
As you can see from the above pic I removed 1 of 4 screws holding the hatch handle assembly. I was able to route the camera cable through that hole. In order to make it clean around the license plate I had to drill a hole through the license plate and license plate backing. Then I simply tucked any excess cable under the license plate. I was happy that I did not have to make any modification to the car and that the hatch handle assemble was well secure with 3 of 4 screws remaining. However, I may just use some silicon if I find that the handle assembly is not 100% flush (Thanks for the tip!)
Now I need to figure out which wires to connect the camera to. I can't seem to figure out which set of wires to use. I can see a brown wire which I read was supposed to be a ground wire for the reverse lights. However, right next to it was a blue/yellow wire. I read that it should be blue/grey so I'm a little confused.
Any ideas on how I could figure out which wires to hook up to?
Thanks again!
Thanks again!
Perfect Thanks!
Wiring is done and everthing works just fine. I used the brown wire for the ground and the blue / yellow wire for the camera / positive. I had a little trouble with the connector / Scotch-Lok since the wires from the camera are 1/2 the size of the wires from the car. If you've used a Scotch-Lok before you'll know that if one wire is too small it will not cut into it. I had to manually cut / scrape some of the tube away from the smaller wires in order to make it work. Luckily that did the trick!
I ended up routing the wire down the inside of the hatch panel and then down the weather striping (see pic)
Then I had to wrap it around the inside panel where the reverse light car wires are located
Temporarly I've mounted the GPS suction cup onto the speedo. I'm not sure I want to mount the ring on the dash? After reading a few threads I'm concerned over theft / vandalism.
Thanks for all your help / suggestions
07-16-2020 12:54 PM
ryGuyMCS
10-20-2015 02:24 PM
Minibeagle
08-13-2015 10:00 AM
minipopkart
08-13-2015 05:22 AM
