Navigation & Audio Replacing the HK Amp & Speakers, Good Idea?
I currently have a working H/K sound system. I was going to put the KDC-X991 in the dash and maybe install new side panel speakers. Would the KFC-1682 be a good choice in sound quality vs the H/K speakers? or should i just keep my h/k speakers? lol.
If you replace the H/K speakers, you really need to remove the H/K amp as well - and then wiring is a challenge, since the speakers are wired to the rear amp position, not the head unit position.
Also, be sure to know that if you change only the head unit, and keep the H/K amp / speakers, you'll need a HKenabler.
minipopkart
08-13-2015 05:22 AM
Drivetrain removing heat shields for turbo cat ?
rckrzy1
08-11-2015 06:06 PM
