Navigation & Audio Navigation Issues
Navigation Issues
My wife has been wanting a Mini for many years and we bought a 2004 recently, however, I'm very disappointed with the Nav system. The navigation system in our 2004 Mini has a periodic problem, sometimes it comes back with a "No disk error message, and doesn't work at all. Other times the disk won't eject. Is there any secret to operating this system? Deeply appreciate any help!
Did you buy an updated DVD perhaps? If so, you will need to update the firmware to get it working right.
Your currently running V20 released in 2003 and the latest is V32. I highly recommend you update as it turns on dual layer capabilities for the MK4. It may solve your problems.
http://www.x5world.com/navigation-system/
You can get it at the link above. Burn the image to a CD and pop in in with the key in the first position.
I have to ask this as it is a common mistake. How did you burn the files? They are an image file meaning that those files contain all the files that need to be on the CD. Just putting those files on a disk will not work.
What was the extension of the files? If they were .nrg, you will need Nero to burn them to a CD.
Try reburning at low speed, or on a different brand of CD disc, or on a different computer drive. The Nav drive is known to be very sensitive to the burn quality of the firmware CD.
I hate mention to this, but since your Nav has had reading issues with both map and firmware discs... well, draw your own conclusion.
Navigation & Audio Question About Mini cd retrofit to Navigation Display
Bank999
Navigation/Audio
08-30-2015 08:51 PM
kyungmanpark
08-23-2015 07:26 PM
