Navigation & Audio large speaker is not work
Its could be the connection at the terminals or the speaker is dead. This speaker is located at the bottom of the front door ( woofer ).
Do you have the H/K system ( States Harman / Kardon on the silver-ish speaker grille ) ?
If so:
Harman Kardon Loudspeaker For HK Systems - Front - Priced Each Part # 65139143273
http://www.ecstuning.com/Search/SiteSearch/65139143273/
If the stock system:
Loudspeaker For Stock Systems - Front - Priced Each Part # 65139143271
http://www.ecstuning.com/Search/SiteSearch/65139143271/
If so:
As suggested...you could swap speakers...give you a chance to look at the wiring...see if the issue follows the part moved...
If it does...buy a new PAIR of speakers.....if the problem stays in the same spot...the you need to look at the wiring, or even the head unit (radio)....
HK systems have lots of amp issues....it becomes a $$$ fix or a complete rewire for a aftermarket radio....
08-12-2015 01:24 PM
