Navigation & Audio Gen 3 audio specs.
Gen 3 audio specs.
Does anyone have the specs for the audio in the gen 3 minis?
I'm thinking about changing my 2012 clubman to a gen 3 Cooper SD but have a concern regarding the front door speakers.
By the looks of it, mini have got rid of the lower door speaker? Is this across the range?
Has anyone upgraded the audio in a gen 3?
What size are the speakers?
Oh im definately going after market equipment, of which I have a lot of already in my 2012 Clubman, but next week I pick up a F56 Cooper SD, so was inquiring about its standard setup etc
I have in my Clubman at the moment the following:
Audison Bit One
Audison Bit Play HD
Hybrid Audio L6v2
Hybrid Audio L1 Pro
Alpine F6 amp
Alpine M12 amp
Diamond Audio TDX12
So play to install most of the equipment into the F56
Audison Bit One
Audison Bit Play HD
Hybrid Audio L6v2
Hybrid Audio L1 Pro
Alpine F6 amp
Alpine M12 amp
Diamond Audio TDX12
Audison Bit One
Audison Bit Play HD
Hybrid Audio L6v2
Hybrid Audio L1 Pro
Alpine F6 amp
Alpine M12 amp
Diamond Audio TDX12
Audison Bit One
Audison Bit Play HD
Hybrid Audio L6v2
Hybrid Audio L1 Pro
Alpine F6 amp
Alpine M12 amp
Diamond Audio TDX12
Keep the audison and alpine stuff, get a set or morel 4 inch components,2 4 inch morel mid woofers and a 10 inch morel shallow mount sub.Focal,rainbow and gladen make underseat 8 inch subs for bmw fxx series cars that the mini is based on.
Had those amps in my r56! Ran focals then morels in the r56. The morel drivers and the Alpine amps are made for each other.
4x 4 inch and 2 6.5 subs under the seats on the base cooper s stereo.
My F56 does not have an amp, it does have the media XL and so on package. No HK or amps. Has 4" speakers in the doors and im guessing 6.5" woofers under the seats.
Does anyone know if my set up uses optical connection? Or has it even without an amp? I tried earlier to take a look behind the media screen for a optical cable but wasnt successful in fully taking the screen secion out to see the connections at the back of it.
Do you have any pictures of the car when you gutted it?
Im still looking into the connections side of things to get my audio kit installed into my F56 soon.
So, if (in my set up which does not have HK) I could tap into the speaker connections before the ASD and use that as high level input into the Bit One?
Also do you have any info on how to take the central display unit out?
Thanks Gregory, ive read a few of your threads, very informative info there, thanks
When you say take the central display out - why is this? Get to the wring?
Keep us posted. Greg
Yes I want to see how its wired up, I think there is an optical connector there. Ideally need to see the wiring from a car with HK, and compare.
I never did a write-up on my previous install. I have a new car now. Here is a post I made on the ASD unit. I will have some helpful diagrams. I also have full stereo colored coding drawings somewhere but would have to dig. Let me know if this ii enough?
https://www.northamericanmotoring.co...esign-asd.html
If you could dig out the full wiring drawings that would be amazing , much appreciated.
Yes I read about the ASD module, i plan to bypass it
hi Gregory, I was wondering if you knew which colour coded wires come from the head unit that I can use as an input into my Bit One?
Hope this helps.
