Navigation & Audio Listen to radio while using Google Maps on iphone
Old 01-09-2016 | 07:28 PM
jaep1911's Avatar
jaep1911
I got a question for you experts.
I was using Google Maps on my iPhone 6 connected to my BASIC audio via the USB and liked the fact that the voice command was heard through the audio while listening to the music stored on my phone. The voice command even slightly muted the music just like the nav system that I have in my MB. Brilliant!
Then I wanted to listen to non-internet radio stations so I pressed the "Radio" button, I got tuned in a local FM station and a song started playing but then the Google Maps went totally silent. No voice command was heard from either the audio system or the phone itself. The map was still working though.
Well, since I switched to the radio on the audio system, I guess the phone was disconnected in the system (while still being hardwired) but I do not understand why the voice command did not start coming out of the phone.
In a situation above, do I need to unplug the iPhone to have the voice command through the speaker of the iphone?
Is there any trick to keep the voice command coming though the audio system while playing the non-internet radio?
Thanks in advance!
Old 01-19-2016 | 05:48 PM
MarcoPolo's Avatar
MarcoPolo
never disconnected. it was still connected, but only via the USB output. you switched to radio, so the only radio sound was being heard.
just like a receiver @ home. you switch to CD or DVD or AUX. you cant' listen to 2 of them. only one. same on the mini.
Old 01-19-2016 | 06:23 PM
jaep1911's Avatar
jaep1911
I got an advice from someone on the other board about activating "Play as Bluetooth phone call" in Google Maps and it now works while playing the radio and my iPhone is still connected to the system via the BT. The nav voice command comes through the audio speakers along with music and it even mutes the music upon commandd.
Sorry I should have posted this early and closed the thread.
Cheers
Old 01-20-2016 | 12:47 PM
siriuszero's Avatar
siriuszero
This tip also applies to the Apple Maps app too as well as several other navigation apps.
Old 04-03-2016 | 08:35 AM
KKelly's Avatar
KKelly
Cheers
How do you activate "play as bluetooth phone call" on an iPhone? I can't find the setting.
Old 04-03-2016 | 11:29 AM
siriuszero's Avatar
siriuszero
In Google Maps, tap the three horizontal lines (menu or "hamburger" button) to open up options, then go down and tap "Navigation Settings". It's in there.
For Apple Maps, I'm a little fuzzy on the exact details, but I think you open up the Settings app and go to Maps and it's in there somewhere though the wording is a little different.
Old 04-03-2016 | 11:31 AM
KKelly's Avatar
KKelly
Ok, I found the setting on Google maps -- do I have to do anything special to get it to work on apple maps?
Old 06-29-2016 | 10:51 AM
perryinva's Avatar
perryinva
Does "Pause Spoken Audio"'in iphone Maps do the same thing when connected via BT?
Old 06-30-2016 | 10:55 PM
perryinva's Avatar
perryinva
Well, I have that checked, and both Maps and Google maps work regardless of the source of "Entertainment" selected. My problem was that I have the Nav with HK and while the Phone volume was correct, it appears that when you make a call, it mutes the "Entertainment", which makes sense. But I made the call, then tried the Siri activated Nav. All I had to do was hit the same volume control, either on the dash or the Steering wheel WHILE switched to whatever "Entertainment" I wanted to listen to, or even the Nav screen. But if you are making a call at the same time, your iPhone based Nav instructions are muted. I can understand now why this all happens, but at the time, while driving, it was confusing. The Mini system uses the same physical volume controls for everything, but remembers each device independently. Smart, but not intuitive.
I just have to remember to use each car, the 2008 MCCS with built in phone BT and Viseeo Tune2Air BT, and the 2016 MCC with Nav & HK differently.
AngeloCarrion
12-23-2015 12:09 PM
zenkatt
12-17-2015 12:52 PM
Blugoose
12-14-2015 10:31 PM
silence2-38554
12-12-2015 06:33 PM
Quick Reply: Navigation & Audio Listen to radio while using Google Maps on iphone
