Navigation & Audio XM in a Cooper Convertible?
Has anybody successfully installed XM in their convertible using the XM Direct/Blitzsafe method?
Does the convertible have the same compartment in the boot that has the CD changer connections in it? Is the install the same as in the hatch?
Also, I haven't come up with a good spot to mount the antenna on the convertible, so if anybody has any suggestions, feel free to share.
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
Originally Posted by mbabischkin
Don't know about your other questions, but as for mounting the antenna, just put it on the dash. I've had my Sirius antenna there for a year and a half and it works fine. I have a Subaru with the antenna on the roof, and I've found that the reception is pretty much the same in the two cars, the signal drops in the same places no matter where the antenna is...
I've done XM Direct/Blitzsafe on my MCSC. The cables for the connection to the Blitzsafe are hidden a bit ore than on a non-convertible. Basically, they are behind the trunk (boot) liner on the passenger side just behind the rear seat. You need to be able to move the liner back to get to the cables. When I first started the install, I took off some of the rear plastic trim to make removal of the liner easier. You can probably get by with just removing the screw on the liner and flexing the material - it bends pretty easily.
I was able to hide the Blitzsafe inside the liner once it was attached and I ran the lines to the XM Direct tunerout the top of the liner. The XM Direct sits in the space above the rear wheel well. If you put it there, you may want to use velcro to fasten it.
I have the antenna mounted over the right rear light assembly. I've had no issues with reception loss from there and it is easy to pop back into the trunk if you are leaving the car parked for a long time at a public lot. I'd also suggest felt or some other soft backing if you put the antenna there so it won'ts scratch your paint.
When the weather gets warmer, I want to see about routing the antenna to the front of the car, placing it next to the factory antenna.
Let me know if you have questions. I can try and take some pics of my install if that would help.
Originally Posted by mcsc
What about the XM my-fi, the personal xm player that broadcasts to any fm stereo with no direct connections. Anyone have any experience with this?
Here some of indimi pictures of the install. These helped thanks
https://www.northamericanmotoring.co...00&ppuser=1892
Thanks in advance
Thanks in advance
![Thumbs Up](https://www.northamericanmotoring.com/forums/images/smilies/thumb-up.gif)
08-14-2015 01:45 PM
08-14-2015 01:44 PM
