Navigation & Audio H/K Stereo.. How to add an amp, or whatever I need to boost volume
Old 09-08-2005 | 10:16 PM
GOPGuyCA's Avatar
GOPGuyCA
First off, I'm sorry for starting this thread, I see the sticky for sound upgrades on the main page and went through there looking at the links but have no idea what any of it means or what I am even looking for.
As I am sure you are all familier, the sound isn't loud enough. My friend says I need to just add an amp. He says most cars have amps under the seat, I don't know. I have no idea.
So... What can I do to upgrade the sound? Do I need to add an amp under the seat? Replace all the speakers, or what? And is it something I can do myself or will I need to take car to the shop? I have no idea what I need or what to do or where to look.
If someone could please help me I would greatly appreciate it because I'm just going crazy with the volume never going up.
Old 09-09-2005 | 04:04 AM
pyratio's Avatar
pyratio
Coordinator :: Hawaii MINI Motoring Club
make it louder!
--Hmm you know it's funny that you say that your H/K isn't loud enough because the H/K upgrade is an amp and possibly some better speakers. I think they said it's a 330watt system already. I could be wrong though. But if you don't think your current H/K system is loud enough you probably would need to replace that H/K amplifier. Make sure it is a MOSFET amp. Those are higher quality because they produce a lot of consistent power and the sound is a lot cleaner with a lot less interference from other electrical do-hickys in your car. Also you'll need to do a little research to see if your stock speakers can handle the power your new amplifier is putting out, or you might damage them. If they can't handle the power you want then you'll need to purchase replacement ones. Infiniti speakers, polk and sony are three of my favorites. I don't particularly care of Pioneer speakers and stay away from kenwood and jbl.
There's also the possibility that something is wrong with your stereo. When I test drove a Mini Cooper S auto with an H/K I couldn't turn it too loud without rattling the windows. Although I did turn it down a lot to listen to the supercharger whine. (what a sweet sound!) But having your dealer check it out might be a good idea.
One other way to increase volume and clarity is to add soundproofing to your car. If you don't care about weight increase or racing then this should be no problem for you. Talk to some of the bigger car stereo places in your area. Some strategically placed sound proofing could give you better focus of sound in your car.
What kind of music do you listen to? If you're lacking bass, or that little boom then adding a subwoofer might be what you need. I have a 8.5 inch bazooka subwoofer that has its own internal amplifier built it and it is more than adequate to rattle my current car. I'm planning on keeping that subwoofer and installing that in my Mini later.
Hope I've helped. Good luck in setting up your stereo to your needs. I love music while I drive. It's my best friend on long drives.
--pyratio
Old 09-09-2005 | 08:15 AM
chows4us's Avatar
chows4us
See here http://www.mini2.com/reviews/review10.html
All you wanted to ever know about the HK
Many people think its way to quiet. Just go to your local automotive stereo shop and ask ... or do some homework first and go to crutchfield.com and see what fits in a MINI.
Yes, you will need a bigger AMP. Depending upon how powerful it is you might need better speakers.
Its all a personal choice.
Old 09-11-2005 | 06:33 PM
MadisonMini's Avatar
MadisonMini
It's not that easy
You can't just swap out the HK amp and put in a bigger one. That's the problem with the HK system, the amp is the "brains" of the whole setup and the entire sound system depends on the HK amp being there.
There's a link of gbmini.net about adding an amp in series with the existing HK amp, essentially using the HK as a line cross-over with the real amplification done by the new amp. But this is definitely not for the faint of heart.
A lot of people after knowing the future expandibility limitations of the HK are disappointed the didn't go with the stock Boost radio and do mods after.
Old 09-12-2005 | 07:29 AM
LeeL's Avatar
LeeL
Definitely check out Ians page at www.gbmini.net . He probably has more info than anywhere else.
Alos, for the H/K, always make sure you keep bass and treble at halfway or lower. The second you go above halfway, the amp cuts volume.
Old 09-12-2005 | 07:34 AM
Tit's Avatar
Tit
Mikey at www.newministuff.co.uk may be able to help you too....he also sells some of Ian's (GBMini) stuff as well...
Old 09-12-2005 | 04:20 PM
GOPGuyCA's Avatar
GOPGuyCA
Thanks for replies..
I wish I went with the stock system! I did alot of research on the Mini before buying and everyone said the sound isn't loud enough in both the stock and upgraded. Alot of reviews said just to get the stock and then upgrade after market rather than the H/K as it would be a waste to upgrade on top of the upgrade and what not. But I really thought that people were exaggerating. They weren't!
My friend told me that most cars usually have amps underneath the seats. He said all I really need to do is add an amp down there or something. I'm just not sure how or what or where. I'll go check out them links you all posted and see what I can find.
And yeah, I always have the bass at either the middle or a little under the middle... I don't like the bass being too loud, makes it where you can't hear the lyrics or anything. And the Treble I play with... Some songs sound louder with the treble all the way up, some with it in the middle. So I don't really know.
I wish there was a quick fix to this. =(
Oh and I listen mostly to BoA, Britney, Utada, Tatu, Jeanette, Lorie, Ayumi Hamasaki, ABBA, etc... I guess pop.
Old 09-13-2005 | 12:28 AM
MadisonMini
If you want to replace the HK amp ...
You need a new amp that can reliably drive the 2 ohm HK speaker coils - and remember the rear speakers each have two coils! You also need a crossover for the doors mid/tweeter pair (in the HK amp, the "crossover" is internal to the amp).
If you remove the HK amp, the stock HU reverts to varying its speaker level outputs with volume - but you still don't have RCA levels.
I think if you want to replace the amp, you probably should consider replacing EVERYTHING!
This is from Ian Cull's post in the 3rd thread in this forum. He runs the gbmini.net web site. His last point is most valid here. It's not as easy as "looking for an amp under your seat".
Old 09-13-2005 | 06:40 AM
LeeL's Avatar
LeeL
You need to look at Ian site. On teh right side iof the page he has a MINI Themes link to info about the steror. Everything he has writtin about MINI stereos is there. It will be very usefull.
Also, THere is lots on info here about what happens when you turn the bass or treble up over halfway. I can promise you that you are getting reduced output if you do it.
Filmy
15
06-06-2023 06:27 AM
Filmy
04-28-2019 11:37 AM
Filmy
09-07-2015 11:27 AM
Sailorlite
09-04-2015 07:03 PM
09-02-2015 11:15 AM
Quick Reply: Navigation & Audio H/K Stereo.. How to add an amp, or whatever I need to boost volume
