Navigation & Audio Mini Aux Port Enabled, Mini USA is Dragging, I beat them to
Old 03-14-2003, 02:53 PM
MiniPilo's Avatar
MiniPilo
MiniPilo is offline
I will get a pay light photo today if I can get home before it gets dark. work is so busy, and I have had no time for a quick brake. My friend was amazed at how will it looked, and fit.
  #27
Old 03-14-2003, 04:24 PM
mpemburn's Avatar
mpemburn
mpemburn is offline
My hat is off to you dominicminicoopers. What font are you using? It looks perfect. :smile:
Mark
  #28
Old 03-15-2003, 09:18 AM
dominicminicoopers's Avatar
dominicminicoopers
dominicminicoopers is offline
Just sent it to ya via email!
  #29
Old 03-16-2003, 05:58 PM
MiniPilo's Avatar
MiniPilo
MiniPilo is offline
Here is the picture of the Input to the aux port
[img]www.thepilo.com/images/auxportinput.JPG[/img]
_________________
mini.thepilo.com
  #30
Old 03-16-2003, 06:10 PM
Driving_Hamster's Avatar
Driving_Hamster
Driving_Hamster is offline
This looks pretty clean. I take it the line runs from that toggle input to the headphone jack of your MP3 player?
  #31
Old 03-17-2003, 05:04 PM
wactuary's Avatar
wactuary
wactuary is offline
This is great! Where did you get the documentation for the head unit? Could you make available a better scan of it? I'm curious to play with Tel + and Tel -. I bet with some creative jiggering we could enable the hands-free via the stereo! Also, curious that the pins are labeled "TV", or am I reading it wrong?
Looking at these pictures, I wonder if one could fabricate a makeshift adapter to plug into the third bank (or those with the NAV could just augment the one supplied). Having a printout of which pins work is sure easier than what I was planning on doing (trial and error!). Glad to see that with patience, my plan would have worked, since it really is only 3 wires to enable the AUX.
Great Job MiniPilo!
Wactuary
  #32
Old 03-19-2003, 04:58 PM
Chayse's Avatar
Chayse
Chayse is offline
I was able to find some plugs that fit the head unit just fine. I have the AUX input enabled and I did not cut up the factory wiring. The pins are a .100" pitch spacing. Computer headers use the same spacing. I bought two ps/2 mouse add-on connectors for $2.50 each. I cut off the DIN plug and used the six pin computer side connector to plug into the back of the head unit. I have enough pins available to enable the aux input, phone input and nav input if I want. When I get the chance, i'll post some pictures of the adapter that I made.
Fred
  #33
Old 03-20-2003, 12:43 PM
nelsdvn's Avatar
nelsdvn
nelsdvn is offline
You can aslo use the wire used to connect a CD/DVD to a sound card. Three wires, red white and black with the perfect size plugs for the radio pins. Pictures of the described wire on on the mini2 thread....
  #34
Old 03-22-2003, 03:26 PM
Skvarcius's Avatar
Skvarcius
Skvarcius is offline
I pulled out my head unit today to see what I was up against. i didnt have the heart to start snipping wires. I'm going to wait until I can hunt down the part numbers for the white plug w/ black insert, and pins, or a clean alternative.
here's a few shots of the pins and the black insert.
http://analog.rm-r.net/~ken/harness/harness1.jpg
http://analog.rm-r.net/~ken/harness/plugside.jpg
  #35
Old 03-24-2003, 07:39 PM
MiniPilo's Avatar
MiniPilo
MiniPilo is offline
Still no word from MiniUSA.. nothing about the release, and no responce to my e-mail that I sent them in regards to the fact the mini comunity has a working Aux Input, and it was not from them. MINI USA are you out there ?
  #36
Old 03-25-2003, 06:12 PM
Skvarcius's Avatar
Skvarcius
Add me to the list of people that have this installed and working. I used an audio cable designed to run from a sound card to a cd-rom. I pulled the pins out of the plug and inserted them into the mini harness. They locked in place when the black insert was slid into the white harness. I then soldered the loose wires to an old headphone cable I had. I shrink tubed everything. The cable comes out at the very bottom of the plastic trim under the switch panel down near the carpet.
There’s no problem backing this out in the future if need be. The cd changer pins can be snapped back into the harness, the harness moved to the other position, and I’m back to where I started.
I plugged in my Ipaq and get crystal clear sound.
If anyone is looking for good mp3 software for the Ipaq, I strongly recommend taking a look at:
http://40th.com/wce/
Thanks everyone for your hard work and help!
  #37
Old 03-29-2003, 03:50 PM
caddman's Avatar
caddman
caddman is offline
cool
  #38
Old 03-30-2003, 08:44 PM
wjklos's Avatar
wjklos
wjklos is offline
Take a look at Gabriel Bridger's site [http://bridger.us/mini]. Apparently there is now a part number and a picture for the new AUX port!
Bill
07-16-2020 12:54 PM
penguinhomey
38
07-07-2019 09:24 PM
flredmini
04-05-2016 06:21 AM
tr3y003
10-22-2015 10:48 AM
mini pooper
RSR Motorsports Coverage
08-05-2015 02:56 PM
Quick Reply: Navigation & Audio Mini Aux Port Enabled, Mini USA is Dragging, I beat them to
