Navigation & Audio Swapping HU on H/K sys with Nav question
on
i know this has to have been done. I have one simple question for anyone with nav who has swapped out their HU for a different one.
Did you lose the Nav voice? if not was there anything special that you had to do or that was required? (wiring harnesses/wiring, etc.)
I'm still waitin on my MINI, but I will be swapping the HU for an Alpine 9857 and my stereo guy told me that I would lose the NAV voice. I don't wanna lose that.
Note:
If you have the H/K upgrade, you have to do a lot more than simply replace the HU, even before you start worrying about whether or not the NAV voice will still work ...
http://www.gbmini.net/mtblog/archive...g_harmon.shtml
As for the NAV voice, I believe it is a signal fed into the back of the HU so you'd need a similar facility in the aftermarket HU, or you could look at something like this from NewMINIstuff:
http://www.newministuff.com/new/shop...ductshow&id=51
Note that NewMINIstuff are also the only company that sell the HKenabler, which solves the H/K amp issues mentioned in my link above:
http://www.newministuff.com/new/shop...uctshow&id=116
on
I'd suggest sending an email to Mike Wildman at NewMINIstuff - or to member MikeyTheMINI here (same person!)
I think he might have addressed the NAV / HKenabler issue - I remember him asking me about it. Something to do with higher volume levels.
on
![Thumbs Up](https://www.northamericanmotoring.com/forums/images/smilies/thumb-up.gif)
on
The problem with the enabler & the nav interface is that the nav voice comes out VERY loud.
An alternative option is to cut the speaker wire coming from the drivers door under the dash & splice in the nav interface there. ( I have done this on a couple of phone installs when a HK enabler is used in the past few weeks)
Also I have heard a rumour that alpine do some kind of nav interface but I have not seen it ( I am not an alpine dealer)
on
kevinminict
06-03-2016 01:31 PM
Navigation & Audio help identifying a couple wires
yashmack
08-15-2015 03:11 PM
