Navigation & Audio H/K Radio ?
H/K Radio ?
I had my 04 MCS in for service and when returned the radio sounded different. Did not seem as Crisp, and I found when going through menu it displayed " mini h/k " and this never displayed before. The dispay no longer showed " electronic" as a choice. Does this seem possible? Only service done was oil change. Any info if someone can steer me in the right direction. THANKS in advance
There is no difference in the headunit with HK and Non-HK. The difference is that if you have HK, some features on the radio are enabled and others disabled. the mini H/K setting is normal setting for us h/k folks, but you should have the electronic setting as well. It could be that they performed a system rest and possibly reset all of your settings. I would say that you need to carefully look and if it isn't there, then you might try the battery disconnect and see if you can get it back.
patsum
10-01-2015 06:33 AM
