Navigation & Audio OEM Nav: Yards, not feet
Somewhere in the a couple of software updates, my NAV slipped into what I've seen called European default mode (or something like that).
Not that big a deal, except I've lost two things: the emergency feature (which offers up your current lat/long), and measurements in feet (it's either meters or yars now, which ain't so cool).
I heard two suggestions online (on NAM, and at X5 world):
1. Disconnect the battery. Didn't work, only reset my clock and stuff.
2. Pull the OBC and instrument cluster fuses. I found a diagram here. I took this to mean some combination of the following:
Anyone know the right answer?
F5 5A Control module for instrument cluster/Diode (From Electronic immoblizer control unit)
F9 5A Control module for instrument cluster
F10 5A Navigation computer/On-board monitor control unit/Radio control unit
F21 10A Control module for instrument cluster
F22 15A On board monitor control unit/Navigation computer/Eject box
F40 5A Control module for instrument panel/Switch panel/Steering angle sensor
Nothing.F9 5A Control module for instrument cluster
The general opinion has been that only the dealer can set the NAV back to USA mode. However, check out the relatively new NavCoder application on X5 World. It is able to set language options and perhaps region as well. You might ask member daflake (NAM and MINI2), who is also in Germany and has some posts on NavCoder.
ej
11-17-2015 09:21 PM
Navigation & Audio Aftermarket radio with OEM navi question
quality_sound
09-12-2015 05:55 PM
Sc00terbum
09-11-2015 07:17 AM
