Navigation & Audio R56 speaker replacement how-to
Old 08-12-2009, 02:41 PM
Robin Casady's Avatar
Robin Casady
Robin Casady is offline
It has been too long since I installed the Kappa tweeters in the A-pillars, but I don't recall it being difficult.
  #577
Old 08-17-2009, 02:10 PM
coreygo's Avatar
coreygo
coreygo is offline
Originally Posted by tesseract
  • I soldered a length of speaker wire onto the speakers and poked it out through an incision in the nearby rubber grommet, as several of you suggested. I didn't want to cut the OEM connectors off the wiring harness, so I used some of the insulation-displacement style splice connectors. I realize this is less desirable than soldering, but I have prior experience using the connectors in high-vibration environments (robotics and marine) and I expect they will be fine.
My Kappa's came in, now trying to find the best way to connect them up. I'm really curious if you can just open up the Tyco connectors and expose the wiring, this way you don't need to cut the wires and can hopefully reuse the Tyco connectors later if needed.
I'm still a bit concerned about the 10.9t tweeters, man they fill solid compared to the OEM's but cutting that plastic with the dremel... yikes, I guess I just don't have the nerve yet to physically modify bits of the car. Oh well I guess, only $110 to get back to original A-pillars...
UPDATE: Also just realized that I'm hitting the high/low level problem using the 693.9i's for replacement 6x9's. Seems Infinity changed the design from .7 and none of their 6x9's have separate inputs for the highs and lows. I'm thinking I could just cut the wire and bypass their crossover. I'd probably just feed the 6x9 directly from the existing 6x9 wiring, then use the tweeter wiring to input into the Infinity cross over outboard thing. Not really sure that's a good idea though.
I've totally killed one A-pillar at this point, though I think I may have found a really good mount option for the 10.9t's. Though if I've screwed that up I'd hate to screw up my brand new 6x9's too .
  #578
Old 08-19-2009, 12:54 AM
coreygo's Avatar
coreygo
coreygo is offline
Unfortunately I think I might have messed up the drivers A-pillar holding bracket. I used the Dremel to remove the excess bits but I think perhaps I didn't remind the right portions of it to get the tweeter to sit correctly and tightly to the plastic.
It'd be really awesome if someone that's done this could take a few pics and highlight the bits that were cut and removed to make the tweeter fit.
I'm going to see if I can work something out with mine but most likely will have to pop for the left side replacement. Holding off on the right side till I can get it figured out.
I had thought I could use the bracket that came with the tweeter itself. To do this I literally cut out everything holding the OEM tweeter in place. It was super secure. There's that little pillar that can be seen once you remove stuff. I used this as a peg and a screw hole for the mount. I then used two pieces of the plastic as supports and glued it. Great, secure, looked good. Worked for me.
I got it down to the A-pillar and went to install. I think its butt is just way too big with that Infinity bracket, there's just no way I could get that plastic at the back near the window to stay, plus get the white pegs in place.
Oops
So tips or ideas are definitely appreciated at this point. I think maybe I could just use some hot glue and take the plastic body from the tweeter to best fitting edit of the A-pillar plastic. But I don't know.
It's almost a shame there's not an aftermarket replacement plastic solution to allow for more widely used tweeters.
  #579
Old 08-19-2009, 03:52 AM
toolazyforalogin's Avatar
toolazyforalogin
toolazyforalogin is offline
there is absolutely no way that any of the infinity brackets will fit back there.
  #580
Old 08-19-2009, 10:45 AM
Robin Casady
I'll be opening mine up soon to remove the Kappa tweeters. I'll try to take some photos, or at least describe what I did.
I haven't decided whether I'll put the new Image Dynamics tweeters in there, or in the door.
My CXS64 V.2 - Image Dynamics 6.5" 4 ohm Component System is supposed to ship today, and should only take two or three days to get here.
  #581
Old 08-19-2009, 12:14 PM
coreygo's Avatar
coreygo
coreygo is offline
I may have just figured something out, basically I took the weird I-mount thing from the tweeter, cut everything off of it, cut it in half. This lets the tweeter still mount inside it and hold it securely. The butt of the tweeter sticks out a bit. What I plan on doing is gluing the mount to the pillar near that little peg that sticks up. I've basically gutted the pillar and there's no mounting plastic left. It's a shame I can't get a complete custom A-pillar made from this. But whatever.
Thanks, I'm tempted to wait and do the other one unless my hack works out.
If everything I've remembered in this thread is right, then don't the upper speakers get the complete unfiltered signal? If that's the case then shouldn't a 4" two-way like the 42.9i's I bought actually have a good signal to both the woofer and tweeter?
If that's the case then wouldn't your ID's have the same deal. There's still something nice about seeing nice tweeters in the A-pillars though.
One major issue I've just run in to with the 42.9i's is that Infinity has started using this "direct connect crossover" cabling.
http://www.myharman.com/images/products/KAPPA42_9I.jpg
There's just no way for the 42.9i to fit directly in there, I can't seem to get the housing apart on the stupid thing either to route it through the hole where the OEM speaker cable gets through there, there's a nice little spot for it to rest if I could.
I've cut the crossover off, if the upper speaker gets the full signal then I'd imagine I actually still need it right? I'm going to just butt connect the cable back together after I actually get the speaker mounted. This is really the only way I see to use the speaker. If I'm mistaken feel free to let me know.
  #582
Old 08-19-2009, 12:45 PM
MotorMouth's Avatar
MotorMouth
MotorMouth is offline
you are gonna love those ID speakers! I wish I could afford to get thier horns.
  #583
Old 08-19-2009, 12:51 PM
toolazyforalogin
This is why I went with the 42.7i rather than the 42.9i - but I do remember thinking to myself that there was plenty of room behind the OEM 4" to use the 42.9i when I was putting in the 42.7i - you sure you can't wrap it in concentric circles to make it fit?
  #584
Old 08-19-2009, 01:13 PM
Robin Casady
Prices aren't bad at woofersetc.com. I ordered the lower price CTX65CS for $180, but they called and offered the CXS64 V.2 for $250.
The CTX69 6 x 9" 2 Way are $160, and the 4" CTX4 2-way are $100.
  #585
Old 08-19-2009, 01:15 PM
coreygo's Avatar
coreygo
coreygo is offline
Yeah, unfortunately I tried that but the outboard crossover is huge, shame since it doesn't need to be. I tried wrapping it and pushing it in there every which way but no go.
I would've totally gone for the .7's but Infinity didn't have them available anymore. I would've probably gone with something else entirely except I bought everything for less than $300 shipped. Hard to complain about that
  #586
Old 08-19-2009, 02:16 PM
Robin Casady
Some people have reported putting the crossovers in the door armrest. Here is a DIY on putting a Redline leather cover on the armrest to help you with removing it.
  #587
Old 08-19-2009, 02:25 PM
toolazyforalogin
Wait don't you have the HiFi? So you can cut the crossovers off and only connect the midrange and leave the tweeters unconnected. Doesn't that speaker has two sets of inputs (one for tweeter / one for midrange ) ?
  #588
Old 08-19-2009, 02:44 PM
coreygo's Avatar
coreygo
coreygo is offline
Thought about this but the wiring isn't long enough so I'd have to cut anyway. I'll post pics up when I get it mounted in there.
Yeah I've got the HiFi. The .9's no longer have multiple inputs they've got some weird funky outboard crossover for my 4" speakers as well as the 6x9's I bought. It definitely seems like Infinity made things more complicated for people by trying to simplify things with their crossover and integrated wiring in the speaker.
I guess I need to examine the speaker a bit more closely since I'm not sure how they could have this outboard crossover yet only have 3 wires going to the speaker. There appears to be a board of some sort that the woofer and tweeters are soldered to. It definitely would've just been a whole lot simpler if they had just gone with two inputs... Leave the crossovers in the amps and outside of the speaker.
  #589
Old 08-19-2009, 02:49 PM
MotorMouth's Avatar
MotorMouth
their round speakers aren't too expensive but I said horns.
http://www.woofersetc.com/p5007/CD2C...loy-Driver.htm
Actually the horns have come down in price but still a bit pricey.
The horns can get extremely loud with very little power. The ones i linked to have a recommended power of just 30 watts - and they'll be louder than any round speaker with 400 watts.
  #590
Old 08-19-2009, 03:42 PM
coreygo's Avatar
coreygo
coreygo is offline
Okay makes sense now. From the outboard crossover they've got a single wire for the signal for the tweeter and one for the woofer. There's a shared ground wire. Simple enough. I guess that makes modifying the 6x9 later a bit easier, I'll cut the wires going to the woofer and butt connect those to the wires from the amp directly. Then I'll plug the tweeter signal to the outboard crossover of the 3-way 6x9.
  #591
Old 08-19-2009, 05:57 PM
Robin Casady
Oh.
That might not be necessary. IIRC, the woofer wires for the 6x9 were only filtered at the bass (oddly enough) and otherwise had full range. Try connecting the crossover to the woofer wires and drop the tweeter wires.
  #592
Old 08-20-2009, 01:54 AM
coreygo's Avatar
coreygo
coreygo is offline
Well good news. The mod I did for the Infinity tweeter mount worked, literally I cut everything off of it and cut it in half depth wise. The little nubs remain to lock it in place and it's secure. I then just hot glue gunned the mount to the curved bit furthest away from seats. It's totally secure and fits well. It doesn't appear to be quite as angled back though, not sure it'll really matter tbh.
Anyway, I've also managed to mount the 4" as well as the 6.5". The 4" was a total PITA thanks to butt crimping the outboard crossover and such. There's barely any room to do it. It doesn't help I messed up the wire lengths either and so on. The 6.5" was super easy. It's kind of hard to tell if the tweeter and woofer are both getting the right signal in the 4"...
So all of that is done on the drivers side. The passenger side is still stock everything and remains untouched.
I probably spent the past hour just sitting with my head in the middle listening to stuff as I panned left and right comparing.
So far... I'm unimpressed I must admit. Unless I have the wiring wrong (though I did check the +/- twice) there's really no discernable difference between the left Infinity's and right stock. In fact the stock almost seem to have a tighter punch. What's really amusing is that when I set everything to 0 the sound just blends together and you really can't tell anything has changed at all. I would've thought there'd be a bigger difference between the two sides much like mis-matched speakers in a home theater. There's not though.
I'm hoping that getting the other side in will make me appreciate it more or somehow make it sound different. I think it'd be more of a placebo though since it'll be hard to compare once the stock is completely out.
Right now I'm wishing I had just fixed the rattles in my doors from when I bought the car and stuck with the stock speakers. I got a great deal, but even then, this seems like a lot of work for barely any return.
  #593
Old 08-20-2009, 08:27 AM
Robin Casady
When I installed the Infinity Kappas I noticed a significant improvement in clarity. I'm surprised that you can't tell the difference. The stock speakers were very muddy compared to the Kappas. However, I'm finding the Kappas too bright and will replace them.
  #594
Old 08-20-2009, 08:57 AM
Nrob's Avatar
Nrob
Nrob is offline
I know nothing about speakers, most of what's posted in this thread sounds like a foreign language. Could someone please just tell me what some good sounding, not to expensive speakers would be, and also where I can buy them. Also, I defiantly will not be installing so if anyone is in the St. Louis area and know of a place that would do a good job let me know. Thanks.
09 MC no HIFI
  #595
Old 08-20-2009, 09:57 AM
Robin Casady
This thread is supposed to be about how to install speakers. Probably best if you add to a another speaker recommendation thread, or start a new thread.
  #596
Old 08-20-2009, 12:31 PM
coreygo's Avatar
coreygo
coreygo is offline
Listened to them a bit more on my way to work. I can definitely tell a difference in clarity with some more material. I guess I just wish it was a bigger jump.
The biggest improvement has definitely been in the mid range there's no more muddy mess.
  #597
Old 08-23-2009, 01:05 PM
coreygo's Avatar
coreygo
coreygo is offline
With the left side done and sounding good finally did the right side. Wired everything up but the right lower wire coloring doesn't seem to match up with what's posted... unless I'm missing a post, keeping in mind this is for a HiFi system.
Was basing it on this:
Right front lower: yellow/brownstripe +, yellow/blackstripe -
Right front upper: blue/blackstripe +, blue/brownstripe -
But my lower has yellow/gray stripe and yellow/purple stripe. It doesn't help the OEM connector doesn't have any indications either.
Any ideas?
  #598
Old 08-23-2009, 02:19 PM
Robin Casady
My iData 3 records have:
Front Right Woofer (6 1/2")
39 - Yellow/Purple (+)
40 - Yellow/Gray (-)
Black and white stripes seem to be positive. Gray and brown stripes seem to be negative.
  #599
Old 08-23-2009, 03:16 PM
coreygo's Avatar
coreygo
coreygo is offline
Awesome, thanks for the confirmation. That's pretty much what I guessed from doing the left side. Wired it that way, sounded good, but just wanted to be sure.
  #600
Old 08-23-2009, 04:07 PM
k6rtm's Avatar
k6rtm
k6rtm is offline
I have a test CD made by Denon -- Audio Technical Test CD -- among other things it has tracks with simple things such as a voice saying "Left channel" from the left, right channel, phase checks, and the like. When I did my bass test CD, I included those tracks, and have them on my iPod -- very useful for those simple things!
(Prompted by a question from Robin -- I updated the CD title. The one I have dates from 1984, early in the history of CD, but it does show up on Amazon!)
Last edited by k6rtm; 08-23-2009 at 05:25 PM. Reason: The voices -- and Robin had a question
Quick Reply: Navigation & Audio R56 speaker replacement how-to
