R50/53 making a noise at high rpms
Old 08-28-2007 | 07:01 AM
pimpedout97x's Avatar
pimpedout97x
When I'm at high rpms, I can hear this kind of clinging noise...I guess that's how I would describe it, but I only hear it when the air and radio is off. U can kinda hear it outside, sounds like its coming from under the car, kinda like the sound of light rain drops dropping on a metal roof or something, I don't know, its weird... Anyone know what I'm talking about? Lol
Old 08-28-2007 | 04:18 PM
Some Guy's Avatar
Some Guy
May just be a loose heat shield. That specific range of RPM's is just the right frequency to get it to vibrate against something. I had a GMC Suburban that would make noise like that at idle and be fine everywhere else.
Old 08-28-2007 | 06:09 PM
pimpedout97x
wheres the heat shield? that could be what it is.
Old 08-28-2007 | 07:32 PM
Some Guy's Avatar
Some Guy
Well there are several. Most of them are used to protect the inside of you car from the really, really hot exhaust system.
The one that protect the engine from the heat of the header is pretty obvious (and probably the most likely culprit). It just sits back towards the firewall behing the engine. You will know it when you see it.
That said it doesnt have to be a heat shield. It could be any shield in the general area of the engine meant to protect something from something else. For example a loose grill for protecting a fan.
If it were me i would have somebody rev the engine to where you usually here the noise and try listening around the engine and the car for it. That should help you narrow the location down so you can start a visual search.
Good luck.
Old 08-28-2007 | 09:24 PM
pimpedout97x
ill keep yall posted on what i find. im going to try this Thursday
Svejk
02-24-2019 12:18 PM
theblackfalcon
10-11-2015 09:49 AM
DWooderson
08-20-2015 04:31 AM
wind715
08-11-2015 07:56 AM
quickquest88
08-08-2015 08:45 PM
Quick Reply: R50/53 making a noise at high rpms
