R50/53 What To Expect After 3 Foot of water
Old 09-09-2007 | 01:23 PM
MiniDaMoocher's Avatar
MiniDaMoocher
Originally Posted by dianna912
Sorry, MiniDaMoocher, I took so long typing my post I didn't realize you had posted a very similar story.
No problem. As you say, if you have never been one, you can't imagine how fast the situation changes.
BTW, call me Mooch. Much easier to type.
  #27
Old 09-09-2007 | 01:50 PM
billie_morini's Avatar
billie_morini
minihune,
the wheel bearings are not sealed to 100% isolation. The things that happen to bearings and their grease that are submerged is that some grease is removed and some grit is deposited. Bearing grease sticks pretty good and is pretty good at preventing water from entering the bearing under normal use conditions. After I run my 4x4 through streams, rivers, and lakes for 2 days or so, I'll replace the bearing grease. The primary reasons are to insure there is enough grease; that it has not been affected so that it lubes and cools properly; and to remove grit. In my street cars that have been flooded, I repack the bearings with new grease. It is easy to do and is inexpensive. Relative to new autos, especially my MINI, the factory was pretty stingy with grease and oil. Every time I look at a hinge or take something apart, wheels included, there was never sufficent lube to begin with. Combine this with street cars that see higher and higher constant speeds than my 4x4 and you have a likely need to repack the wheel bearings in an auto that has been flooded.
Use a bearing packer. It looks like cymbals, one of which having a zerk fitting on it, and a grease gone to repack wheel bearings properly. These tools are cheap. The job is easy.
  #28
Old 09-09-2007 | 08:07 PM
89AKurt's Avatar
89AKurt
You didn't have this option? What a bonehead.
Hope it works out for you. Phoenix's old freeways dip under the bridges, and some storms overpower the pumps, so I know what you went through.
  #29
Old 09-09-2007 | 08:09 PM
Dr Obnxs's Avatar
Dr Obnxs
Have you done this on a Mini?
Originally Posted by billie_morini
minihune,
Looks like the hub assemblies are sealed units. But that's just from REALOEM, and I haven't tried this on a Mini. My mustang, sure, the packer is fine, but I'm not seeing that the bearing races can be removed on our cars.
Matt
elverado
01-18-2022 02:51 AM
Supertractor3
04-07-2017 11:16 AM
misterbl
09-16-2015 11:22 AM
BadgeFTW
09-14-2015 03:49 PM
gzaos
09-14-2015 04:21 AM
Quick Reply: R50/53 What To Expect After 3 Foot of water
