R50/53 What oil
Old 02-20-2008 | 06:16 PM
rrcaniglia's Avatar
rrcaniglia
"The latest service category rating for gasoline engines is "SM", introduced in November 2004 for 2005 and newer engines. SM-rated oils along with the previous "SL" (2001) and "SJ" (1997) ratings, are backwards compatible and can be safely used in older engines. But the opposite is not true. Older obsolete service classifications (SH, SG, SF, etc.) may not meet OEM lubrication requirements for newer engines. Likewise, API SL oils should not be used in 2005 and later vehicles, and SJ oils should not be used in 2001 and newer vehicles." (http://www.aa1car.com/library/motor_oil_605.htm)
  #27
Old 02-20-2008 | 06:28 PM
aorr's Avatar
aorr
Sweet! Thanks guys. Sorry for the impatience I had. I just noticed my oil level was a bit lower than it should be and was needing to get some in there quickly. :-)
  #28
Old 02-20-2008 | 06:41 PM
NoModMini's Avatar
NoModMini
..Mobil1 0-40.....the only AEAC A3 spec......every 5000 miles.....
  #29
Old 02-20-2008 | 06:50 PM
rrcaniglia's Avatar
rrcaniglia
NoModMini, I don't believe you. That Mini in your pic has had some MAJOR mods.
  #30
Old 02-20-2008 | 06:57 PM
NoModMini's Avatar
NoModMini
_________________________
...oh yeah....i forgot.....turned it around....and added some body work
  #31
Old 02-20-2008 | 07:04 PM
ScottinBend's Avatar
ScottinBend
I thought that was a Porsche..................................
  #32
Old 02-21-2008 | 05:53 PM
AstroBlackS's Avatar
AstroBlackS
Just ordered some Royal Purple 5w40.
Here is what the description says:
"Royal Purple 5W40 motor oil delivers all of the performance of other Royal Purple motor oils plus meets API SM & CF and ACEA A2 - 96 & A3-02 (European) requirements. 5W-40 is become more widely used and demand is growing rapidly for this viscosity. Not intended for diesel applications."
  #33
Old 02-22-2008 | 11:16 AM
oliverm's Avatar
oliverm
Mobil 1 0-30, change every 12K.
  #34
Old 02-23-2008 | 05:11 PM
javelina1's Avatar
javelina1
Mobil 1 0W-40, AND German Castrol 0W-30 are ACEA A3/B3 & BMW LL-01 spec oils.
The next best thing is the BMW supplied Castrol 5W-30. it's NOT the same as the USA off the shelf Castrol 5W-30. USA 5W-30 does not meet the specs....
At a min. buy the BMW supplied stuff. Otherwise, anything that meets ACEA A3/B3 and BMW LL-01 will suffice.
  #35
Old 02-23-2008 | 05:55 PM
resmini's Avatar
resmini
I'm pretty sure changing to Royal Purple gave my '03 MC a few extra horsepower.....maybe.
  #36
Old 02-23-2008 | 08:11 PM
rrcaniglia's Avatar
rrcaniglia
Need some advice. Is the Royal Purple European formula (5W40) OK to use in an R56 MINI? The manual calls for 5W30, but isn't the R56 engine european?
  #37
Old 02-23-2008 | 08:15 PM
minimarks's Avatar
minimarks
Royal Purple
  #38
Old 02-24-2008 | 10:37 AM
javelina1's Avatar
javelina1
the "spec's" will set you free... if it's ACEA A3/B3 & BMW LL-01, all is well.
  #39
Old 06-03-2008 | 12:12 PM
hiyoslvr's Avatar
hiyoslvr
Amsoil 5W-40 European Formula
  #40
Old 06-03-2008 | 02:22 PM
cristo's Avatar
cristo
Alliance Member
Currently, Amsoil 5W-40 Euro also, since passing the warranty and free
service periods.
Previously, had alternated between MINI 5W30 (when free via the dealer),
and Mobil 1 extended 5W30.
  #41
Old 06-04-2008 | 05:24 AM
resmini's Avatar
resmini
I use Royal Purple because their advertising about increased HP sounded good.
  #42
Old 06-07-2008 | 06:51 AM
javelina1's Avatar
javelina1
naw... that's Slick 50....
  #43
Old 04-10-2009 | 05:31 PM
cphilip's Avatar
cphilip
I bring this back up because YOU DON"T WANT ANOTHER OIL THREAD!!!!!
But there are many here stating that Castrol Syntec (US Formula) does not meet the Spec. However I find the bottle says it meets A5 and B5 and also says so at their site: "Exceeds European ACEA: A1, A5, B1, B5,... and all requirements of ILSAC GF-4" http://www.castrolsyntec.com/grades.aspx
A5 is a newer higher rating is it not? Designed for long drain intervals too IIRC.
So is this new or what?
  #44
Old 04-11-2009 | 07:09 PM
Some Guy's Avatar
Some Guy
This is what interest me. If our cars have been around since 2001 does that mean they were originally specced for SL oil?
  #45
Old 04-12-2009 | 08:36 AM
DaveTinNY's Avatar
DaveTinNY
I just put 5QTS of Mobil 1 Extended Life (the gold cap) Full Synthetic 5W-30 on my first self made oil change. :-)
  #46
Old 05-01-2009 | 11:50 PM
Samdaman's Avatar
Samdaman
What do you guys think of the Walmart Synthetic oil (Super Tech) which is apparently Exxon/Penzoil depending on what coast you're on.
  #47
Old 07-15-2009 | 07:32 AM
dwebber18's Avatar
dwebber18
Stick with BMW Castrol, Mobil 1 euro, Royal Purple, or Ams. I wouldn't use Exxon/Penz in my old jeep
  #48
Old 07-15-2009 | 07:55 AM
JimRoberts12's Avatar
JimRoberts12
there is always redline. whenever i end up doing my own oil, that's what i'll use
  #49
Old 07-15-2009 | 08:00 AM
SlowGSX98's Avatar
SlowGSX98
I used to use Mobil 1 5w-30, but the OEM Castrol is cheaper for me and the dealer is on my way to work so I've switched over to that.
CardinalsRule
06-11-2016 04:34 PM
molala
10-02-2015 01:53 PM
09-04-2015 09:10 AM
09-03-2015 03:01 PM
09-02-2015 09:05 AM
Quick Reply: R50/53 What oil
