To me, that speedo is a defining MINI characteristic. Getting a MINI without it was getting "something else". Not to say it is the end all and be all of MINI ownership, but it is a defining item that I wanted present, and opted against a car with NAV so that I could get it.
There are a number of aftermarket ways you can get the extra gauges if you want more vehicle info in Real Time. Not sure what your plans are for modding.
I understand that sentiment exactly as thats what I thought originally. I guess I am kinda drawn to the extra gauges which I really like, and I am not a big fan of aftermarket gauge set ups...
I like the center speedo look, but I like more having the oil temp, oil pressure, and water temp gauges in my chrono pack. I also like not having to look somewhere other than the front when checking my speed.
Chrono all the way! No such thing as too many gauges, plus I like the speedo and tach side by side directly in front of me as well. BIG mistake for the new generation to not offer the extra gauges.
Unfortunately, the Chrono pack does not have traditional analog gauges. One (or both) of the temperature gauges is merely an idiot light made to look like an analog dial. It only has 3 needle positions (low, normal, high).
DH ordered the chrono pack for me because he *didn't* like the big center speedo. And honestly, I was just stoked and totally freaked that I was even getting a Mini! I don't miss having the speedo in the center.
I can confirm that the Oil pressure and Oil Temp are real-time gauges, and not idiot lights. I think the water one is also, since when it is really cold up here, the needle moves to the top a lot slower, and starts off at different positions depending on how long the car has been sitting.
I am so used to the center speedometer because my first car was a MINI. Now I look to the center for the speed in all cars, then remember it's behind the wheel. Who's dumb idea was it to put speedometers behind the wheel anyway?
Then I stand corrected. I thought it was what I had seen posted by others.
Me, too. I wish this myth would die. My Scangauge tells me basically the same thing for H20 temp as the Chrono Pack gauge... now, that said, the way the gauge is calibrated, there is very little difference between, say 193F and 205F... and very little between 250F and 220F... so if your car is running just *a little* hot, you probably won't notice by looking at the gauge...
I too like the center speedometer. But I spec'd out the chrono pack for the additional information provided on round gauges. Never can have too much info.
