R50/53 Why spend so much on your cabin air filter? Alternative here
Old 09-04-2008, 10:02 PM
motionmonk's Avatar
motionmonk
motionmonk is offline
Thanks Xymox for sharing this with us all...
I just bought 2x from Logical Source with expedited shipping for $22 and change for my 2006 MCS.
I'll post back here once I get them and change it out
  #102
Old 09-05-2008, 11:40 AM
Thoroughly Modern Mini's Avatar
Thoroughly Modern Mini is offline
I just got mine in the mail today. I can't wait to change it and get rid of the stinky socks smell inside!
  #103
Old 09-05-2008, 11:53 AM
ajakeski's Avatar
ajakeski
ajakeski is offline
Got mine. Installs and works like OEM.
  #104
Old 09-05-2008, 12:07 PM
schreiber117's Avatar
schreiber117
schreiber117 is offline
Thoroughly Modern MiniI just got mine in the mail today. I can't wait to change it and get rid of the stinky socks smell inside!
just a quick tip. when you change the filter you can add a couple dryer sheets on the outside of the filter, helps get rid of the smell, without those stupid pine tree things.
It works like a charm, and the dryer sheets are built to have air flow through them, so no risk.. just make sure its set up as follows:
outside air -> dryersheet -> filter -> vent
otherwise the dryersheet will get blown into your vent system, which could be a problem
  #105
Old 09-11-2008, 03:21 PM
motionmonk's Avatar
motionmonk
Ok, finally found the time to install my filter...
-first off, use a flashlight the first time you do this.
It's hard to see upside down, and you don't want to break the tabs off the plastic cover.
-when you pull out the filter, have the plastic bag that the new filter came in handy. My old one was filled with gunk.
-look for the arrow showing air flow on the end of the filter; you want to make sure you put it in right.
-since the filter curves up and back into the vent system, don't be afraid to push it up and in.
Keep the edges flat on the filter housing, and it should slide right in place.
Big difference! I run re-circ air almost all the time to avoid fumes and dust...
I think I'll go to a 9-month cycle from here on in.
thanks again Xymox for the heads up!
  #106
Old 09-11-2008, 07:12 PM
I put mine in the other day... took all of 7 minutes.
  #107
Old 09-11-2008, 08:53 PM
djmini420's Avatar
djmini420
djmini420 is offline
just ordered mine. cant beat the price. thanks xymox
  #108
Old 09-13-2008, 11:42 AM
Brother_Bluto's Avatar
Brother_Bluto
Brother_Bluto is offline
Originally Posted by rustyboy155
Cheap!
Anyone used parts from that company before? I'd be concerned that the quality wasn't up to snuff with OEM.
TYC is a quality aftermarket (& OEM) company that will stand behind their products. We've been selling their cooling & lighting products for years. I've seen their filter line during a tour of one of their distribution centers and would not hesitate in using the product.
  #109
Old 09-15-2008, 08:47 PM
AutoXCooper.com's Avatar
AutoXCooper.com
AutoXCooper.com is offline
Location: Car Nut Since 1987, Owner Since Fall 2005, Vendor Since Fall 2007
yet another reason to change it more often. Mine is the one on the right after just 20K
  #110
Old 09-15-2008, 11:59 PM
beasleyboy's Avatar
beasleyboy
beasleyboy is offline
Um, you all have me a bit confused. I can't find the spot on the website where he found the filter. What NAME are you clicking on in the manufacturer's links? Mini is not listed and it's not under BMW as in BMW-Mini either.
  #111
Old 09-16-2008, 05:49 AM
AutoXCooper.com
Originally Posted by Xymox
So it's time for a new cabin air filter, your MINI is beginning to smell like a gym locker room. I pulled my cabin air filter and nearly wretched at the ghastly sight of it. Utterly filthy. FYI, you're *suppose* to change them every 12 mo./12,000 miles.
So I hit the usual MINI places. OutMotoring prefers to charge you $42.95 (which may not even be carbon activated). And MiniMania would like to charge you $56.95 for a carbon activated cabin air filter. Not likely!
I found a brilliant alternative. The site is A to Z Autolights ( www.atozautolights.com ). They carry the OEM replacement made by the company TYC. Not only is it nearly identical to the OEM (3M Company) replacement, but it's carbon activated too! And the cost? $8.31.
Just looking out for my fellow thrifty motorists.
it's in the 1st post above.
  #112
Old 09-16-2008, 06:05 AM
p912043's Avatar
p912043
p912043 is offline
Now they sell it for US$ 12.00 still cheap
  #113
Old 09-16-2008, 04:16 PM
Crashton's Avatar
Crashton
Crashton is offline
I bought 3 of them for less than the $37 cost for 1 from Classic MINI. They fit well & seem to be of the same quality as the OEM filter.
  #114
Old 09-17-2008, 06:29 AM
Ords's Avatar
Ords
Ords is offline
Excellent price and this is something I totally forgot about after 2 years and 56k miles on the car!
Edit; Ordered same day as my post and delivered already!
  #115
Old 09-17-2008, 06:35 AM
Crashton's Avatar
Crashton
Crashton is offline
I was thinking my AC was getting weak. When I pulled the old filter out I saw why. That darned thing was about plugged solid with all kinds of nasty carp. With the new filter in there I find myself running the AC fan one notch slower now. The air is moving once again.
  #116
Old 09-17-2008, 06:49 AM
Martin Brenneke's Avatar
Martin Brenneke
Martin Brenneke is offline
Bought and installed the filter 2 weeks ago. The air flow in the cabin seems to be greater now and all is working fine. At the price and looking at the construction it is a quality product and the price is right.
  #117
Old 09-17-2008, 01:35 PM
gran turismo's Avatar
gran turismo
gran turismo is offline
I just ordered one for shipment to Edmonton, Alberta. Total cost was $29. I had to place the order over the phone as they don't support the online order placement for Canada.
  #118
Old 09-17-2008, 06:53 PM
djmini420's Avatar
djmini420
Just installed mine. I order last friday and got it in 2 days..fast and cheap. awesome. thanks
  #119
Old 09-21-2008, 11:00 AM
wearlaz's Avatar
wearlaz
wearlaz is offline
What year were you searching for? I had the same problem when I searched for model year 2008. It appears they either haven't updated their online system to show parts for 2008 MINIs or they don't carry them (I suspect the former).
I sent them an email asking if they have the products I'm looking for. Will report back as soon as I find out.
  #120
Old 09-22-2008, 08:37 AM
Mini1966's Avatar
Mini1966
Mini1966 is offline
Gee, do you need one in a Convertible?? lol
  #121
Old 09-26-2008, 06:24 PM
swissarmybottle's Avatar
swissarmybottle
swissarmybottle is offline
this was the simplest install ever.... 5 minutes from opening the passenger door to completing the mission!
I ordered this part Tuesday night and it arrived Friday morning (delivered to San Jose, CA)... should've ordered more than one =/
  #122
Old 09-29-2008, 07:59 PM
CARdiac's Avatar
CARdiac
CARdiac is offline
Thanks for finding this! do you have a line on a good inexpensive oil filter?
  #123
Old 10-01-2008, 02:24 PM
lordgrinz's Avatar
lordgrinz
lordgrinz is offline
Interesting, I finally got around to trying to change this, mine looks nothing like the replacement. The original has no plastic on it, and the new one with the plastic didnt want to fit as nicely. I gave up and put the original back in since it was clean and fit better.
  #124
Old 10-03-2008, 09:33 AM
bamatt's Avatar
bamatt
bamatt is offline
Thanks for the Amazon heads up. I just ordered 2 which qualified for free super saver shipping so I got 2 for $37.98 total (It was almost $6 for shipping or spend another $6 & get free shipping). I hope I can get the new one in when it gets here
  #125
Old 10-09-2008, 07:34 AM
gran turismo
I received my filter last week and installed it on the weekend. I definitely suggest using some type of lubricant when putting in the new filter. My old one was extremely dirty and was obviously hindering air flow. I was very impressed with the entire process. FYI, I'm in Canada and you have to phone directly to place an order.
I'm thinking of replacing the filter twice a year from now on.
Quick Reply: R50/53 Why spend so much on your cabin air filter? Alternative here
