R50/53 Anyone running staggered rims on their MINI?
Old 07-11-2008 | 07:00 PM
Eurothrasher's Avatar
Eurothrasher
Anyone here know if we can run staggered rims on a MCS ? Nothing too drastic, like a .5" wider rear rim/tire ?
Old 07-11-2008 | 07:07 PM
muladesigns1's Avatar
muladesigns1
i am only running 7" all around, but youll see a few on here running 9" in the rear!
but the trade off is the tire has to be stretched in order to not hit anything and the rim ends up sticking out further then the tire.
the disadvantage to running staggered sizes is you loose the ability to rotate. if you have a performance tire, then you could end up burning through it in as little as 8K since you cant rotate it.
i myself do like the slightly staggered look too.
Old 07-11-2008 | 07:41 PM
Eurothrasher
wow, 9" would be out beyond the OEM rear fender. I was thinking like an inch wider.
I have seen some .5" t0 .75" wheel spacers, but that design seems to place most of the vehicles weight on the 4 lugs - instead of the lip on the hub ? Am I correct with that assumption ?
Old 07-11-2008 | 08:40 PM
muladesigns1
I know a lot of people on here run spacers and have not had any problems, but i also know of a lot of people that have spacers on other cars and run into steering issues.
myself, i would not run them, I would get a wider rim, the.5-.75 your looking to get. then have it made with proper offset and backspacing.
07-16-2020 12:54 PM
minicoclub
08-25-2015 09:07 AM
bleonard1401
08-11-2015 02:53 PM
Lt. Dan
08-10-2015 12:46 PM
nomar116
08-09-2015 09:42 AM
Quick Reply: R50/53 Anyone running staggered rims on their MINI?
