R50/53 04 MINI Cooper S vs. JCW MINI Cooper
If you are referring to the JCW motor, the differences between it's engine and an 04 are as follows:
Slightly modified head
Bigger injectors
Different air intake
Internals of supercharger coated and smaller pulley attached
Higher flow stainless steel exhaust w/ different tips
Different ECU programming.
I believe that covers it
Bigger injectors
Thats due to the reduced pulley size on the JCW cars. The superchargers themselves do not create different PSIs... You can put a reduced pulley on a non-JCW car and have more PSI as well... The superchargers themselves are nearly identical, the only difference being a coated inside of the JCW supercharger, that the 04 MCS did not have... The 05-06 Superchargers had the coating from the factory...
07-16-2020 01:54 PM
12-23-2015 11:36 AM
PelicanParts.com
08-04-2015 03:45 PM
