R50/53 How Do I Fix a Rattling Window?
Old 10-21-2009 | 10:04 AM
blacter's Avatar
blacter
The driver's side window on my '02 has a bit of a rattle. It shows up when I shut the door with the window up. I've got the door panel off, but I don't see an obvious fix. Have any of you dealt with this? Thanks.
Old 10-21-2009 | 10:34 AM
JAB 67's Avatar
JAB 67
There are adjusters that regulate the angle of the window regulators, which thus controls the closure of the glass to the upper seal. There are two, one at the bottom of each 'leg' of the regulator. With the door panel off look down into the cavity. And, lay on the ground and look up at the bottom edge of the door. You will see the screws the lock the position of these adjusters.
Old 10-21-2009 | 10:46 PM
chaseabryant's Avatar
chaseabryant
in addition to the above, check and make sure the (what I can describe only as cogs!) that hold the window in place are tight. With your door panel off, and your window partially down, maybe a third of the way, reach up into the door on the portion of the glass that faces the outside of the car. In line with each track, there are cog shaped washers that fasten the window glass to the track. Each has an attached screw in the middle that fits an allen head wrench. First make sure that the "cogs" are at least hand tight, then you can tighten a little more with the allen wrench. Be careful not to tighten too much though, as there doesn't seem to be any sort of padding (be it fiber or foam) washer between these "cogs" and the glass.
From there, I'd say try the above method, it also works wonderfully for those that have a bit of wind noise/whistle or who have a bit of trouble with water seeping past the seals.
Good Luck!
-Chase
BernieCoop
09-10-2021 03:15 AM
UncDeo
11-04-2019 04:08 AM
embiggenedmini
10-15-2015 12:36 PM
09-03-2015 02:06 PM
hardy616
09-02-2015 08:32 AM
Quick Reply: R50/53 How Do I Fix a Rattling Window?
