R50/53 Sunroof Controls
up on the roof is the button. Press it up (like you are trying to press it through the roof) and it will open the vent. Slide it towards the rear to open it and do the opposite to close. It will auto-open but not auto close.
There is also a programable option to hold the unlock button to open all the windows and the sunroof.
If you use the key to lock the door you can hold it there and it will close all the windows and the sunroof.
(The unlock toggle on the dash also works.)
on
1 Post
Hmmmm....my sunroof has the automatic open AND the automatic close feature.
As mentioned above, press the button to open the vent (which you can vary, depending on how long you hold the button), and move the other thingie back towards the boot, to open the sunroof. If you quickly double-touch it, it will automatically open...move it back toward the bonnet to close, and quickly double-touching that will activate the auto-close function.
My keyfob is programmed to open the windows and the sunroof when I press on the wing logo for 5 seconds or more. And when you exit your MINI, you can put the key in the lock, turn it to the right, and that will close the windows and the sunroof.
Hope that helps.
Clo/Wanda
Hope that helps.
Clo/Wanda
Bugs me that the sunroof stays in the vent postion and doesn't close all the way on the one-touch function. Keep thinking that I will accidently forget to close it and it will rain or something. Never had a sunroof in another car. Is this a normal thing that it only closes to the vent positon on one-touch?
Navigation & Audio HK Replacement With New Components
Filmy
15
06-06-2023 06:27 AM
Colt45Magnus
09-14-2015 03:12 AM
