R50/53 MY BUILD UP, continued...
Old 06-17-2011, 02:08 PM
cmt52663's Avatar
cmt52663
cmt52663 is offline
Welcome back...
  #352
Old 06-20-2011, 08:54 AM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
DICKS GARAGE R53 is offline
And it starts!
Dispite the rain in Denver today, my tank is half full of E85 with the other half regular 91 crap gas. I just ran my first set of idle logs, and it's a bit lean. Thats to be expected, I havent altered the fuel tables yet. The KNOCK levels are averaging around a 40, so I can bring timing up even at idle.
I will post more as I go along today, I am taking the week OFF of the day job so I have time.
  #353
Old 06-20-2011, 11:26 AM
DICKS GARAGE R53
Just made my first series of adjustments. The first ride revealed that I had the global fuel map (controlls the strength of the injector pulse, used to scale the injectors) set pretty close from the adjustments I made in the garage. I was still pretty lean down low, and was a few points off of my target AFR midrange. My timing also needed some small tweaks, the KNOCK levels are down pretty far across the board, so I will be playing with it to see what I can do.
Now its time for another ride, to get some more logs.
  #354
Old 06-20-2011, 04:40 PM
DICKS GARAGE R53
Well after the 3rd set of adjustments, all is pretty good again! AFR holds steady at around a 12.3ish but drops to an 11.7ish at 7K rpm, pretty much perfect for alcohol. Yes 12's are lean for pump gas, but with the added protection of the alcohol you can get away with running a little lean as long as your KNOCK is in check.
I just made a couple more minor tweaks, loaded it to the car, and after I get something in my stomach I'll git back at it, and go test it out.
  #355
Old 06-20-2011, 07:17 PM
DICKS GARAGE R53
Still leaning out down low for about the first second of all the runs, unless I am already on the throttle. I think I am missing something, I already sent a message out to the Boys of Mynes.
If this last adjustment dont work, I'm calling it a day until tomorrow.
  #356
Old 06-20-2011, 09:21 PM
DICKS GARAGE R53
Well I'm down to only half a tank of this mixed gas to burn off tomorrow! All is well, and I cant wait for 100% E-gas. Ahh tomorrow.
  #357
Old 06-21-2011, 06:39 AM
DICKS GARAGE R53
Time to git-r-done! It shuldnt take me long to work out the one or two bugs left in this tune, so I can use it in emergancy's where I cant find E85.
  #358
Old 06-21-2011, 01:34 PM
DICKS GARAGE R53
I just got that perfect idle with 100% E-gas! She purs like a kitten at 945RPM no bumps, no sputters, just holds a perfect 14.7 AFR. It will probably change a little once the adaptives set in, but for now I'm moving on to some minimal load stuff, searching for that magical AFR number.
  #359
Old 06-21-2011, 03:07 PM
DICKS GARAGE R53
Looking good so far, time for a drive, with some log taking.
  #360
Old 06-21-2011, 03:55 PM
DICKS GARAGE R53
WWWWWOOOOOOOOOWWWWW
  #361
Old 06-21-2011, 04:10 PM
joe_bfstplk's Avatar
joe_bfstplk
joe_bfstplk is offline
Originally Posted by DICKS GARAGE R53
WWWWWOOOOOOOOOWWWWW
It's a good thing that you have a windshield, even if it is cracked, 'cause with your mouth hanging open like that, you'd be eating a *lot* of bugs...just sayin'.
C ya,
Dutch
  #362
Old 06-21-2011, 05:06 PM
DICKS GARAGE R53
Joe, when you get to Colorado in August, YOU gotta ride in this thing! (IF size of @$$ supports the size of the seat. )
My AFR's acording to the logs, where a little lean in spots, even for alcohol. I just made some adjustments, and am back on my way out.
  #363
Old 06-21-2011, 07:48 PM
DICKS GARAGE R53
My GLOBAL fuel scale is off , no matter how hard I try it just wont add any more fuel! The first pull looked great but once the adaptations started to kick in everything went to crap. I'm done for the night, time to start again tomorrow, it shuldnt take long, I'm really getting the hang of what to do.
  #364
Old 06-22-2011, 03:04 AM
HRM's Avatar
HRM
HRM is offline
You are clearing the old adaptations out each change, correct?
  #365
Old 06-22-2011, 05:42 AM
DICKS GARAGE R53
Yes I am, and I also wait the 5 minutes for the ECU to shut down every 3rd time, or every time I take it for a drive.
  #366
Old 06-22-2011, 06:49 AM
DICKS GARAGE R53
I am going out to reload the tune before the last one I did. I changed the main fuel map so much in the last one that I would rather change the GLOBAL on the one with the least ammount of fuel added.
The engine is 100% cooled down so it might help some of the COLD START stuff at the same time.
  #367
Old 06-22-2011, 07:56 AM
stevecars60's Avatar
stevecars60
stevecars60 is offline
You're on the right path Sand Man.
  #368
Old 06-22-2011, 09:25 AM
DICKS GARAGE R53
The cold start is still a little rough, but outside of that it's looking real good again. Time for some street logs.
  #369
Old 06-22-2011, 09:52 AM
joe_bfstplk
Looking forward to your report, with even more bug-collecting "eek" faces and an even longer "WWWWOOOOWWWW!"
C ya,
Dutch
  #370
Old 06-22-2011, 12:03 PM
DICKS GARAGE R53
Still no luck with getting enough fuel! I'm going to take some good advise CRANK THE #### out of the global, (well within reason) and see what happens!
  #371
Old 06-22-2011, 12:17 PM
DICKS GARAGE R53
Thanks Mike, Thats a good number.
Oops wrong site!
  #372
Old 06-22-2011, 02:01 PM
DICKS GARAGE R53
Finally getting enough fuel! I really wasnt that far off with a good GLOBAL, so I just made my 1st round of tweaks. I would take it out but the fuzz must of cought on to me, it's looking like a dirty lint trap in my neighborhood! Guess it's time for a break.
  #373
Old 06-22-2011, 02:20 PM
joe_bfstplk
Good to hear you're in the ballpark.
Bummer about the bear infestation in your area. Bears can be a pain. Hopefully they'll wander off soon....
C ya,
Dutch
  #374
Old 06-22-2011, 02:24 PM
DICKS GARAGE R53
The fueling side will be done tonight except the cold start stuff, but the timing stuff will need to wait until tomorrow.
IMHO, my MINI right now would wax the EVO I had when it was stock.
  #375
Old 06-22-2011, 09:52 PM
DICKS GARAGE R53
TUNING AND... TUNING AND... STILL TUNING!
Hey I do have a deadline, if it takes all night to figgure it out, SO BE IT!
Quick Reply: R50/53 MY BUILD UP, continued...
