R50/53 Inspection 1 Question
Old 02-28-2011 | 03:19 PM
ChItalian1027's Avatar
ChItalian1027
My counter for the next Inspection just went down to 0 miles. What is Inspection 1 and what do they look at? I'm bringing the car in to Patrick BMW/MINI here in Chicago to have them take a look at it. Should I not drive the car since it has 0miles till the inspection or is it ok to drive before I bring it in for Inspection 1?
Old 02-28-2011 | 04:16 PM
ScottRiqui's Avatar
ScottRiqui
How many total miles does your 2004 have? "Inspection I" usually comes due between 20k miles and 30k miles.
Regardless, Inspection I is pretty much just a bunch of "check this" and "check that", along with an engine oil change. As such, you can continue to drive it for a little while until you have the inspection done. (Make sure your oil level is good, of course.)
Old 02-28-2011 | 05:05 PM
ChItalian1027
It has 26,894. I got the oil change back in September so all I need is like the cabin filter changed. What is Inspection II?
Old 02-28-2011 | 05:09 PM
ScottRiqui's Avatar
ScottRiqui
Here's a link to everything covered in Inspection I and Inspection II for the first-gen cars.
Old 02-28-2011 | 06:29 PM
ChItalian1027
Ok, thanks Scott. Do I have to get this done at the Dealer or can I bring it into one of the shops that work on Minis?
Old 02-28-2011 | 06:38 PM
ScottRiqui's Avatar
ScottRiqui
Any shop should be able to do most of it. They may not stock all of the correct filters on-hand, but they'll be able to get them. Also, when it comes time to replace the serpentine belt, they may not have the official BMW tool, but then again, they might. Either way, they'll be able to get the job done.
Old 02-28-2011 | 06:49 PM
ChItalian1027
Ok, thanks again Scott
Old 07-07-2011 | 05:02 PM
Tea Rex's Avatar
Tea Rex
I have a 2005 S with 40k miles. The local dealer says I need Insp. I for $700. Does that sound right?
Old 07-07-2011 | 06:52 PM
ScottRiqui's Avatar
ScottRiqui
The price sounds typical for a dealer, but there's really not that much to Inspection I. There's an oil/filter change, along with replacing the engine air filter and the cabin air filter for the A/C. Other than that, it's a lot of "check this, check that", so $700 is a lot to spend unless you don't like working on your car at all.
donniedarko
10-21-2015 01:15 PM
gmonde
09-28-2015 05:22 PM
09-11-2015 01:15 PM
Manny_cooper
09-03-2015 05:48 AM
09-02-2015 09:05 AM
Quick Reply: R50/53 Inspection 1 Question
