R50/53 cv shaft on wheel bearing
Old 06-25-2011 | 01:21 PM
unavolta's Avatar
unavolta
So im replacing my cv axle on driver side. i have it totally out of the car... with the wheel bearing assembly and its stuck to it. its supposed to just pull out but it doesnt and ive been hammering on it continuously and nothing happens it doesnt budge, even with the help of pb blaster. some one please help on a solution. thanks!
Old 06-25-2011 | 03:28 PM
unavolta's Avatar
unavolta
http://www.flickr.com/photos/64484191@N04/5871008046/http://www.flickr.com/photos/64484191@N04/5871008046/ by http://www.flickr.com/people/64484191@N04/, on Flickr
Old 06-25-2011 | 03:32 PM
unavolta's Avatar
unavolta
WP_000335 by unavolta, on Flickr
unavolta's Avatar
unavolta
WP_000337 by unavolta, on Flickr
Old 06-25-2011 | 04:35 PM
HRM's Avatar
HRM
A hammer on the end should do it for you. It just sits there...don't know what to recommend.
Old 06-25-2011 | 07:00 PM
unavolta's Avatar
unavolta
yeah i've hit it with the hammer quite a bit. I'm letting it soak with some pb blaster and gonna try again tomorrow. has anyone else had this problem? im kind of thinking its a rust issue...
Old 06-25-2011 | 07:44 PM
Evasive's Avatar
Evasive
Have you tried heating it up a bit?
Old 06-25-2011 | 08:26 PM
onasled's Avatar
onasled
??? Which way you hitting it? Looks like all sorts of hammer marks on the CV cup, and no marks on the threaded shaft end.
Old 06-26-2011 | 07:39 AM
unavolta's Avatar
unavolta
Evasive - heat gun or torch?
Onasled - yeah, I was hitting the cup in a downward motion. I've hit the threaded shaft so many times it has already mushroomed a bit.
I'm thinking of putting it on a press on Monday to see if it will come out if no other method gets it out here at home.
Old 06-26-2011 | 07:47 AM
onasled's Avatar
onasled
Uh-Oh, ...if you have mushroomed the shaft then it may not pass through the bearing if you do get it loose.
I gaher the cup is to large a diamiter to fit throught the upright hole that the hub sets in if you unbolt and try and remove the hub? If it did then just pull the hub and toss the whole thing.
Old 06-26-2011 | 12:11 PM
unavolta's Avatar
unavolta
yeah i assumed that too when i saw it but it looks as though it doesnt interfere with the splines. yeah that whole assembly comes off, i had just put it on there but i dont wanna trash the bearing because its pretty expensive but i will if i have to.
Old 06-26-2011 | 12:53 PM
onasled's Avatar
onasled
Originally Posted by unavolta
..... but i dont wanna trash the bearing because its pretty expensive but i will if i have to.
With all the pounding with a hammer and the fact that it's even stuck in the first place, I might assume that those bearings are trash already. Don't go through all this work to find you have to do it again in a couple months. Just toss it all and get a new hub.
08-27-2015 10:00 PM
L3Mix
08-26-2015 07:00 PM
JPMontes3
08-23-2015 01:26 AM
robertcoyle
08-18-2015 09:28 PM
sabjcw
08-14-2015 07:40 AM
Quick Reply: R50/53 cv shaft on wheel bearing
