R50/53 Embarassing questions / connectivity
So I'm new to the site and just got a new (to me) 2006 MCS JCW. I'm totally psyched but have a few (very remedial ) questions about connectivity. The car has Nav and HK sound. (I've tried searching the forums first but am having trouble finding this information for my model/year (R53)).
- What is the best way to connect my iPhone for phone calls? I see a "phone symbol" on the multifunction steering wheel. Can I connect via bluetooth and just don't see how? Is there a better solution?
- What is the best way to connect my iPhone for music? I've read that DICE makes a module but it sounds pretty crude. I've also read that adding an AUX port works well. Do I already have an AUX port that I can't find?
curiously you get the buttons even when bluetooth is not installed . . .
the aux port is still available and super easy to install at around $40
http://www.outmotoring.com/mini-coop...pod_mp3_hookup
and there is the GEN1 iPod interface at $250 but as I read the description it is not possible to connect this AND NAV . . .
http://www.outmotoring.com/mini-coop...interface.html
topics like this are best researched in the audio and nav section ... down a few topics on the menu
https://www.northamericanmotoring.co...-and-audio-14/
1. The phone button only works if you install the OEM bluetooth module, which is expensive and complicated.
2. Aux-in is the simplest way, though because you have Nav you can't do the blind install. There is a port in the back of the head unit that the aux-in plugs into. OEM calls for installing the female 3mm(?) plug in the glovebox, so you can look in there first.
Welcome to NAM!
Welcome to NAM!
Parrot makes a better cheaper kit that can be installled....with an adaptor connected to the button...
several different ways to get audio in....from line in jack to oem/aftermarketvkits...
The oem head is a bit limited in some features/controls....it is basicly the same radio going back to '02....added mp3...but interface is the same....so keep this in mind picking you options.
There is an OEM iPod adapter, and it will work. However, if you think DICE seems crude, the OEM adapter is even more so.
No, the DICE module does not work with Nav. It takes over the Nav screen to display track info and renders the Nav itself unusable. They never resolved the problem. There is only one unit (Intravee) that integrates well with the Nav screen but it has been discontinued.
I use this iPod adapter: http://www.usaspec.com/ It works well, but I don't know about use with an iPhone.
If you end up installing an Aux connector, I recommend the factory unit. And I installed mine on the plastic bit that's under and forward of the row of switches in the center. Putting it in the glove box is lame, IMHO.
Also, if you go the Aux route, AND you want to hook up more than one thing to it, there are some great products in the motorcycle world that will help you do that. Here's one: http://www.aerostich.com/mix-it2-multiplexer.html
Interior/Exterior DEPO/Helix Projector Headlights Installed
Alkaidovich
01-30-2021 01:35 AM
kyungmanpark
08-23-2015 07:26 PM
nismo4life
08-05-2015 08:31 AM
