R50/53 New Aux Input DIY Tutorial! (R50 - The easy way)
So I bought a cable to install in my 2004 MC and wasn't 100$ sure how to get started...well I searched and found a lot of different ways of doing it, so I'm going to kind of show compiled stuff that worked for me, pics included!
Note: You do NOT have to remove the whole stereo unit! This way is a lot faster no doubt, and less work.
I'm going to make this very easy:
1. Disassemble glove compartment (do you ever even keep gloves in there?) You will need a hex driver, I always guess the size so do that Don't forget to carefully remove the small light as well by popping it out with a flathead from the right side
2. Pop open valence panel underneath steering wheel, don't be afraid you'll break it. It takes some force, but grab it from the part closest to the bottom of the steering wheel and pull down. If you do break it, lay off the roids.
3. Your hands should now be able to touch behind the stereo if reaching from left and right, but don't do that too long because it's weird to hold your own hand, so now feed the cable (part that will plug into the back of the stero) from the right to your left behind the stereo
4. Now feel right behind the volume **** and you will feel where the cable is supposed to plug in. With the little clip on top of the cable, plug it in and test it to make sure it works
5. Now, using the provided faceplate as a template, use a sharpie to dot where the holes will be drilled to install the panel
6. Drill the holes where you want in the glove box (2mm for screws and 10mm for center hole) ...if you don't have metric drill bits - divide an duse dummy chart
http://bobmay.astronomy.net/misc/drillchart.htm
7. Now pop the cable in, screw on the little circular piece to secure it, reassemble the glovebox, and pop the valence under the steering wheel back into place if you didn't break it. (you won't)
8. Good job.
The nice thing to is you don't have to install this in the glovebox, but I wanted to so I can hide the cable somewhat.
8. Good job.
on
Nice job! To avoid drilling anything, I just got a 6ft (probably too long.) stereo cable and snaked it down below the toggle switches, hidden under the change tray, then tucked in the same place as yours above, and all the way underneath the shift boot cover area. I have about 6" of slack that is coming out between the change thing underneath the handbrake and the seat heater buttons. Almost invisible and I can rest my iPod under the handbrake when I'm driving
A simpler solution would be to pull down the hinged dash piece below the steering wheel. There are no bolts to unscrew and you're already on the side where you need to plug in the AUX cable. However, if you want to install the faceplate in the glove box, your way is definitely the way to go.
on
Usually I remember to have it charged before I leave the house
Minnie.the.Moocher
09-02-2015 01:43 PM
