R50/53 Valeo Clutch Install, which direction?
If you look at the clutch, there's the flat side and a raised side with the "nose". Clutch is labeled "gearbox side" on the raised side but I've read that clutches are almost always labeled wrong. Anyone know if the raised side faces the pressure plate or the flywheel?
We have the guide tubes in stock
http://www.waymotorworks.com/throw-o...-cooper-s.html
As for the bushings I wouldn't bother with them unless they are worn out, they don't just pop out, they are a pain to replace.
squawSkiBum
10-02-2015 09:21 AM
