R50/53 CVT mileage
Mine failed at around 121k miles. I've read of a lot of failures here that happen between 100k and 150k miles, but the majority of those with CVTs running strong don't post, so obviously it's a skewed picture when they're failing.
It was the stepper motor on the valve body that died on my CVT, which is replaceable part, but I opted to put in a more robust 6-speed instead.
My opinion on the CVT is that it is probably just as reliable as a conventional automatic transmission, the only problem with it is no transmission shops are trained to work on them, so instead of repairing a broken one, they have to put in an expensive reman transmission, making the repair an unreasonably expensive one.
The transmission is a 6-speed manual from an S. Way Motor Works in Atlanta did the conversion using parts from a wrecked 2006 Cooper S.
Here's the dedicated thread with folks who have done the swap:
https://www.northamericanmotoring.co...trag-swap.html
http://www.lib.ucdavis.edu/dept/pse/...F%20040323.pdf
88k
I have 88K on my CVT. About 700 miles back, I experienced extreme RPM variation on the highway. I pulled over and exited on the next exit, a few miles on local road later the car went into EP mode. In my case, EP mode restored transmission to normal shifting and I was able to drive 200 miles to get home.
I took my car to my repair shop, it turned out to be a failing rotational speed sensor on the CVT. They found a used part to repair it and it was back on the road for less than $250. It cured the problem completely.
For CVT owners, I believe the key is regular CVT fluid change. It should be done at every Inspection 1 or 2. Unfortunately, many shops failed to do that at service time, and it created a number of early transmission failure.
I'm at 135 but the second CVT first failed @ 96K I replaced the fluid as soon as i bought the car. ~ 10K ago. Fluid was a little dark for my taste and i'll be changing it next spring no matter what the mileage. It's going to be a once a yr thing for me. Change trans fluid and fuel filter. I all my own work so just have to buy parts. Cheap insurance to keep that 5g trans shifting like it should.
I had to replace the entire fuel filter assembly b/c it had a slow leak somewhere causing fuel line pressure loss when the car sat for a few hours unused. It caused extended crank times when starting. All that to say, I would only mess with that assembly when really necessary - and only use OEM fuel filters to be safe (which cost the same).
Alpha Motoring
10-01-2015 10:30 AM
