R50/53 Tire size for 17x7" rim
on
I'm doing a bit of research because I will be purchasing tires in spring. I'm currently running 17x7 BBS RGR wheels with 215/40/17. I was looking online and I came across this page about the new direza ZII star specs coming out in the spring. When looking at they table they say for a seven inch rim to use 215/45/17 or 205/45/17. Is there a problem for me to be running the slightly wider tire?
What is your preferred tire size and why? What benefits do you see in your experience of driving?
http://squarespokes.com/04/news-dunl...able-in-japan/
on
If you are lowered you don't want 215/45-17 since it is slightly taller and wider than stock.
Sizes that are OK are-
205/45-17
215/40-17
While 235/40-17 is possible it is wider than stock and would reduce clearance and increase risk for rubbing in the rear.
Typically for a 17x7 rim the above mentioned sizes will fit and be OK. However with a 40 series sidewall it will be stiff and not good if your roads are poor. In that case try 205/45-17 with a softer sidewall tire for more comfort.
205/45-17
215/40-17
