R50/53 Strut tower plates - is there a "best" choice?
Old 01-09-2013 | 12:43 PM
fridayxiii's Avatar
fridayxiii
Ruffian is going in for an oil change and some rear brakes soon, and I figured I'd let my mechanic throw on some strut tower plates while she's in the shop.
I know Way carries M7 strut tower plates and CravenSpeed, but there are other options too. From the product descriptions they seem pretty similar in thickness and price. So the question, is one brand of strut tower reinforcement plate better than another?
Old 01-09-2013 | 12:53 PM
Eric_Rowland's Avatar
Eric_Rowland
I like the VIP design, which utilizes 'insert nuts' to hold down the plate rather than the M7 which uses the OEM nuts (thus the plate is thinner around the nuts), or the Craven design (which I have) that provides 'cove studs' that go over the strut mount bolts and then larger nuts to secure the STD.
In the end, they all function similarly, so it comes down to how you feel about the mounting systems.
Old 01-09-2013 | 01:30 PM
CravenSpeed's Avatar
CravenSpeed
Vendor
I can tell you that I have never, not once, had anyone tell me that they put the Strut Tower Defenders on and still had a mushrooming problem. I know Way has a set or two in stock for you.
Old 01-09-2013 | 01:43 PM
Helix13mini's Avatar
Helix13mini
I like the Craven ones as well.
Old 01-09-2013 | 08:37 PM
ZippyNH's Avatar
ZippyNH
I've hsd craven std's on since nearly new...no issues. Good looking, fit well. A few folls had fit issues with the m7 ones around a cable/wire (hood release maybe) years back, but bet that has been fixed. Imo craven makes very nice stuff...looks good too.
Old 01-09-2013 | 08:54 PM
minsanity's Avatar
minsanity
Have Craven, too. No issues at all.
Old 01-09-2013 | 09:59 PM
GreekDrifter91's Avatar
GreekDrifter91
i have the craven ones, i was going to go with m7 but i think i made the better choice with the std's.
Old 01-09-2013 | 10:06 PM
rustyeuro's Avatar
rustyeuro
I have the M7 ones and they have actually pulled the metal back a little bit over the course of a year and a half. visually i like the m7 ones better but the Craven speed ones should work just as good. it's a personal choice of color and style in the end.
Old 01-09-2013 | 11:15 PM
Vindr's Avatar
Vindr
I just got a MCS 2013. Is this a big problem on the mini's? Is it more of a problem with aftermarket springs or also stock suspension? Just wanting to know if this is something I should really look at getting or not. Thanks
Old 01-09-2013 | 11:52 PM
drifter.locus's Avatar
drifter.locus
I'm bidding on an m7, I already have the madness plate that fits between the strut mount and the strut tower. Do you think I will have enough threads to mount both?
Old 01-10-2013 | 12:51 AM
rustyeuro's Avatar
rustyeuro
no, you'll either have to choose one or the other.
otherwise you could knock out the pressed in bolts and put 8.8 grade longer bolts in
(not recommended)
Old 01-10-2013 | 01:01 AM
drifter.locus
That"s what I was afraid of. Is there another one that I can use in combination with the plates I already have?
Old 01-10-2013 | 04:52 AM
Mib4840's Avatar
Mib4840
Alliance Member
Congrats on the 13! Yes, it is a common issue. I would throw a set on immediately. Once I read about the mushrooming and did the research I bought a set the next day. Easy to instal but make sure you have a torque wrench. They take a lot less tightening than I expected. I would have tightened them down until I couldn't go any more and that would have been a mistake. It's cheap insurance against "shrooming".
Old 01-10-2013 | 05:00 AM
BlwnAway's Avatar
BlwnAway
They are both going to do the job, just pick the ones you want for the looks, I've had them both, and personally like the extra "beefiness" of the Craven's.
Old 01-10-2013 | 05:11 AM
fridayxiii's Avatar
fridayxiii
Sincere thanks to all for the replies. I'll be ordering the Strut Tower Defenders this morning.
Old 01-10-2013 | 10:52 AM
Eric_Rowland
Either Craven or VIP will use the entire length of the stock strut hat bolts.
Old 01-10-2013 | 11:36 AM
rustyeuro's Avatar
rustyeuro
M7 uses up the entire length of the stock hat bolts also, you have maybe 1 thread beyond the nut left
Old 01-11-2013 | 01:07 PM
javelina1's Avatar
javelina1
M7's are like that as well. I've been using the M7's, since my car was new. (2006 MCS). No mushrooming at. Working just fine.
-jav
Old 01-11-2013 | 09:12 PM
rustyeuro's Avatar
rustyeuro
lol...
ej
11-17-2015 09:21 PM
M7Speed
09-04-2015 10:47 AM
Suspension Products
09-03-2015 09:41 AM
M7Speed
R58 :: Coupé Talk (2012+)
09-03-2015 07:29 AM
M7Speed
09-03-2015 07:27 AM
Quick Reply: R50/53 Strut tower plates - is there a "best" choice?
