R50/53 motor oil selection
Old 10-23-2002 | 07:26 AM
origin98's Avatar
origin98
hi everyone...
the saleswoman at the dealer said that i the first oil change for my MCS won't be until 12 or 15k miles. BUT she mentioned, have some motor oil on you and check the fluids every once in a while and add as necessary. i didn't think to ask what kind of synthetic oil...
i'm running a trip from chicago to nyc next week and thought i should have a bottle of motor oil for the trip. please tell me what brand and sae rating synthetic oil you guys are using..what you recommend..so forth...
it would be greatly appreciated!
02 mcs-drk silv/white
Old 10-23-2002 | 07:52 AM
2minis's Avatar
2minis
If you go over to beneath the bonnet forum and review
the posts there is some interesting info on synthetics.... :smile:
12-15 K...no way. IMHO.
_________________
2Minis
Size matters!!!!!!
Old 10-23-2002 | 08:19 AM
Zappa's Avatar
Zappa
If you do keep the stock filter in there that long be sure to at least change out the filter and top off. This you can do w/o getting under the car.
Old 10-23-2002 | 09:39 AM
Astro's Avatar
Astro
If it was my car, I'd change the oil and filter before the road trip using whatever weight oil is recommended in the manual. I use Mobil 1 in my car.
Old 10-23-2002 | 01:07 PM
Azwed's Avatar
Azwed
Castrol Syntec is the type of oil that MINI uses and it has a a very high, read crappy, volatility rating. Syntec is also not synthetic and that is why you have to top off the oil.
Old 10-23-2002 | 03:14 PM
Bmuelle's Avatar
Bmuelle
I'm going to use Mobil 1 in my Mini. I've used Mobil 1 in my 1999 Tracker and it purrs like a kitten.
Old 10-23-2002 | 03:55 PM
picoman's Avatar
picoman
I just called my MINI dealer and he said that he'd put any oil I want in there as long as I bring it to him and it's a high grade synthetic oil. That's great since now I'm not stuck with Castrol but can still have it serviced my my dealer. Also, since they only charge $48, it's pretty reasonable (not sure if it'll be cheaper if I bring in the oil....hmmm....hope so!)
Old 10-23-2002 | 03:57 PM
picoman's Avatar
picoman
oh and in addition to that, he also said that brining it in after 1500 miles is a good idea. It's not part of the free maintenance, but I'm doing that anyway.
Old 10-23-2002 | 04:40 PM
d-mini-ero's Avatar
d-mini-ero
mobil 1 here....
i changed the oil @ 5k and will also change it @ 10k
no magic here...just common sence :smile:
peace
D
Old 10-23-2002 | 08:09 PM
DK23's Avatar
DK23
Changing the oil is the best thing you can do for your engine. It is cheap, easy, and nothing else will reduce engine wear like clean oil. Full synthetic, (Mobil 1) every 3k miles. Yes, you can run longer between changes, but why would you? Cleaner oil equals less wear. I wouldn't run past the first 1k miles without an oil change, as that is the most critical period, and the time when the oil will be most contaminated by particles from the engine during the intital break in.
DixonL2
04-13-2021 08:05 AM
Zettinger
08-25-2015 04:04 PM
PelicanParts.com
08-14-2015 11:07 AM
Emnotek
08-13-2015 05:47 PM
tippin
08-05-2015 08:43 AM
Quick Reply: R50/53 motor oil selection
