R50/53 HELP!! DIY oil change
Old 03-24-2013 | 04:44 PM
Nitro1's Avatar
Nitro1
So....my first time changing the oil in our 2005 MCS. I followed the DIY instructions completely. I'm not foreign to changing the oil in cars, but this is my first go for the Mini. When I started the car, the oil "under pressure" sprayed like a wide shower out of the bottom of the motor!
The only two things I removed and reinstalled were the drain plug and the filter. I looked under the car and there was no oil coming out of the drain plug and the area around the filter cap is dry. WTF??
I used the mini filter, new plug and mini oil??
What and how could I have screwed up? again, it poured out under pressure when I started the car.
Please help and calm me down. Thx
Old 03-24-2013 | 04:57 PM
ZippyNH's Avatar
ZippyNH
Bet it is a bad o-ring in the filter cap.....unless you really banged something hard on the back of the engine and broke an oil line...very unlikly.
I would check the filter cap oring....but looks like you just have to get under it and look!!
Old 03-24-2013 | 04:58 PM
InVisib0L's Avatar
InVisib0L
2nd on the oil filter cap theory.
Old 03-24-2013 | 05:01 PM
Nitro1's Avatar
Nitro1
Thanks guys.
But why would the cap around the filter be dry then??
I'm going out to check. How would I know if the o ring is defective? I ordered the package from mini mania.com
Braminator's Avatar
Braminator
Old 03-24-2013 | 05:08 PM
Nitro1's Avatar
Nitro1
Gold star for you guys! Pulled out the filter cap and "o" ring was shredded!
Why and how? Before I put in another one...please advise me on the correct way to do this so I don't shred another one.
Old 03-24-2013 | 05:27 PM
InVisib0L's Avatar
InVisib0L
Take your finger and dip it into some new oil and coat the ring before placing the ring on the filter cap.
Old 03-24-2013 | 05:35 PM
Nitro1's Avatar
Nitro1
Yup...Good to go!
Just started the car and all seems good. I probably lost a quart of oil in the spray episode. Ordered some more 5-30 from mini mania.
Question, I started the car...it is no longer spraying or leaking. Even though I lost a lot of oil, if I shredded the o ring again, then it should have had enough oil to spray again? Yes? FYI...the oil pressure light is still off.
Thank guys! Now I can sleep tonight.
Old 03-24-2013 | 05:36 PM
boxter4ever's Avatar
boxter4ever
o ring
Hi,oil coat the o-ring and make sure it is in the correct place on the cap and do not over tighten.
Old 03-24-2013 | 06:21 PM
ZippyNH's Avatar
ZippyNH
Yup...just toss a quart of you favorite oil in, and start driving!!
Mobil 1, etc are all fine....just a good quality syenthic...if you want to use only mini oil fine, top off with a good syenthic oil, and use that at your next oil change....
And check you oil level regularly...mini's burn oil...
Old 03-24-2013 | 10:29 PM
element's Avatar
element
Was the ring in its groove? I wonder how it got so shredded? Dry the last install?
Phil.
Old 03-24-2013 | 11:10 PM
ZippyNH's Avatar
ZippyNH
Phil.
bet it was dry, or it slipped out of the grove, and got caught in the threads.....
Old 03-25-2013 | 05:51 AM
Densmini's Avatar
Densmini
I have had a lot of old British sports cars (50's and 60's) with canister-type oil filters. I was astonished to see what amounted to a return to that on the MINI. What, those clever engineers couldn't figure out a way to use a cartridge? Maybe they were angling for oil-dripping British authenticity.
Old 03-25-2013 | 12:06 PM
Eric_Rowland's Avatar
Eric_Rowland
Just as likely (50/50?) a return for 'green'. Why manufacture a metal case that is designed to be thrown away if you don't have to?
I've got a 54MG - the oil canister is the least of leak worries!
Old 04-12-2013 | 10:21 PM
freestylebiker33's Avatar
freestylebiker33
i have seen allot of people replace there oil filter, and a good habit while taking off your old oil filter is to double check to see if the old o-ring came off with the oil filter. allot of times the old o-ring gets stuck on the engine block, so once you start installing the new oil filter you will end up having 2 o-rings installed ( new and old ) and that's a big reason for oil leaking from the filter area
Kimolaoha
07-05-2023 01:04 PM
woodstudio
03-15-2020 08:28 AM
Colt45Magnus
07-14-2019 06:18 PM
patpatpat
08-27-2015 07:51 AM
HaveATank
08-24-2015 10:26 AM
Quick Reply: R50/53 HELP!! DIY oil change
