R50/53 Group buy on cravenspeed dipstick?
Old 05-17-2013 | 08:31 PM
JoanieB's Avatar
JoanieB
Originally Posted by MikewithaMini
Got mine today too. It sure fits loose in the tube, no friction at all. Is this normal?
No, it's not normal. Let them know and they will replace it. It should fit snugly.
  #152
Old 05-18-2013 | 10:29 AM
Cruzer214's Avatar
Cruzer214
I just received mine and its the same way, it basically just lays on top of the tube without any resistance.
Sent from my iPad using NAMotoring
  #153
Old 05-18-2013 | 10:42 AM
JoanieB's Avatar
JoanieB
I'm not near my car to check, but isn't there supposed to be a little rubber ring around it? Does your have the ring? Can someone confirm that there is supposed to be a rubber ring?
Craven will replace them if they aren't right.
  #154
Old 05-18-2013 | 10:43 AM
Cruzer214's Avatar
Cruzer214
The one pic is from cravenspeed website and the other is what I received. You can clearly tell its a different design which is probably why it doesn't fit snug.
Attached Thumbnails Group buy on cravenspeed dipstick?-image-2751322933.jpg   Group buy on cravenspeed dipstick?-image-2833435796.jpg
  #155
Old 05-18-2013 | 10:59 AM
MikewithaMini's Avatar
MikewithaMini
Yes, the o-ring is the problem. They put the 10 cent one on them instead of the 15 cent one. I bought 3 of the f___ers and they are all the same. I'm a little more than a little disappointed.
  #156
Old 05-18-2013 | 11:53 AM
JoanieB's Avatar
JoanieB
Don't worry, Craven will replace them. Just let them know. They stand by their products.
  #157
Old 05-18-2013 | 11:59 AM
Cruzer214's Avatar
Cruzer214
Joanie, does your dipstick look like mine or the one on cravenspeed site?
  #158
Old 05-19-2013 | 05:23 AM
JoanieB's Avatar
JoanieB
I'm not able to check until tomorrow but will take a photo then.
  #159
Old 05-19-2013 | 07:00 AM
MikewithaMini
Here's mine.
  #160
Old 05-20-2013 | 12:13 AM
MiniKar's Avatar
MiniKar
It appears that the o-ring is the wrong size.
They may just ship you all new o-rings as they are easy to install.
Oh, quality control is not included when things are so pricey . . . . . . . . .
  #161
Old 05-20-2013 | 10:38 AM
CravenSpeed's Avatar
CravenSpeed
Vendor
Good morning, NAM. Sounds like we ran into a problem over the weekend. Well, the solution is already in place, so fear not.
Almost all of the dipsticks for this group buy were assembled just last week as quickly as possible to get them out to you. It looks like the one's that were made last week were made with the wrong o-ring. Not a cheap one, not the one out of the wrong bin (we are better organized than that). We got sent the wrong size, then we went ahead and sent you the wrong size. Either way, I know it is our fault, and we apologize. Here is how we are going to fix it;
http://www.cravenspeed.com/dipstick-o-ring/
Follow the link, put the free part in your cart, and checkout for free. We'll have the correct sized o-rings here tomorrow and we'll send them right back out as soon as we can.
Thanks for your patience and understanding, I am sorry about the error.
-=Kellen
  #162
Old 05-20-2013 | 10:54 AM
yetti96's Avatar
yetti96
Sucks that they sent you the wrong part and you subsequently assembled with the wrong part. Glad you are making it right though. Great job Craven Speed!!!
  #163
Old 05-20-2013 | 10:56 AM
astroBlackMetallic_Mini's Avatar
is this O ring issue with ALL dipsticks, or just the R56, or just the R53s?
  #164
Old 05-20-2013 | 11:02 AM
youloze's Avatar
youloze
I received mine last week (among the first to receive from the group buy) and mine fits great, nice and snug. I think it was only the ones that had to be assembled during this group buy that had the issue as the ones that were already in stock (mine) had the correct o-ring installed previously.
  #165
Old 05-20-2013 | 11:03 AM
CravenSpeed
Vendor
Just R56, and not everyone's. If yours fits well then you do not need to make any change. Only the one's that were most recently assembled have an installed OD of .375 instead of .4, some of you have or will receive properly fitting units.
  #166
Old 05-20-2013 | 11:21 AM
MikewithaMini
I have my order in for O-Ring replacement. I really appreciate the quick response to remedy the situation. I like it when crisis resolution is timely and on point. Thank you!
  #167
Old 05-20-2013 | 11:24 AM
Cruzer214's Avatar
Cruzer214
I wonder if the o-ring on the oem stick would work on the cravenspeed one???
  #168
Old 05-20-2013 | 11:32 AM
WayMotorWorks's Avatar
WayMotorWorks
We've been doing some test fitting today and found that if you carefully remove the oring from the stock dipstick it will work on the Craven dipstick.
We are holding all the R56 dipstick orders from the weekend till we get the correct orings on them and will ship asap once the correct rings are in place.
  #169
Old 05-20-2013 | 12:16 PM
MikewithaMini
I'd bet it might if you could get it off and on the new stick without breaking it. If it has been around for a while, it may be a little brittle and break even carefully peeling it out of the old stick landing. Or it might stretch and be too tight to fit in the tube.
  #170
Old 05-20-2013 | 04:33 PM
LarriB's Avatar
LarriB
The o ring on the original dipstick does fit on the Cravenspeed. I just tried it. I'm going to get new o ring though because the old one IS old and tired.
  #171
Old 05-20-2013 | 05:28 PM
gezz81's Avatar
gezz81
Oh man... with my excitement I did not even realize... mine is loose as well! Order placed and thank you for the speedy fix!
  #172
Old 05-20-2013 | 08:30 PM
Mark97xp's Avatar
Mark97xp
Just ordered, was the shipping supposed to be free?
  #173
Old 05-20-2013 | 09:22 PM
InMyMini's Avatar
InMyMini
For as many as have been ordered and add the error with the O ring...
Plus a lot of the other group buys have at this level.
So one would certainly hope so
  #174
Old 05-20-2013 | 09:28 PM
Mark97xp's Avatar
Mark97xp
Is that a yes cause i was charged $6
  #175
Old 05-20-2013 | 09:46 PM
ibmiked's Avatar
ibmiked
I just placed my order using the link above. Free part/free shipping (and that was to an overseas military APO address). I would definitely send a PM or an email about the shipping charge.
Unfortunate error with the o-ring, but it happens. Thanks for making it right though. Great customer service.
Quick Reply: R50/53 Group buy on cravenspeed dipstick?
