R50/53 Power window broken! help
#26
Regulator comes with everything you see in the picture, those other part I talked about about are for specific issues like rattle or if someone broke the bottom alignment supports.
Most regulators come with everything except the motor ( unless listed in the description ), and those bottom regulator supports. Also dependent on year they can come with additional screws.
For you problem ( with the grinding ) and getting the new regulator as a whole , you should be fine to complete the job as mentioned above.
Thanks and I hope that helps.
#28
I just recently acquired my mini, and when I bought it, all the windows were tinted except the passenger door window. It didn't roll up or down very well and was out of alignment. Somebody had obviously been in there before and messed something up. I tore it apart yesterday and had found that one of the cables came off of a pulley and was riding between the pulley and the rail. After a little detective work and a few choice words, I got it back together and it works beautifully now. Pelican Parts has an excellent write up on replacing the regulator. 4 bolts, 6 screws and 3 clips and the whole thing's out. I'd take the old one out and look at it first and see what you can find before I'd throw parts at it. Good luck.
#30
i just received my window regulator from ECSTunning and i dont think i got what i ordered
ORDER NUMBER: 733-510-753
this is what i received, the screws are missing and i seem to have gotten one window lifter (little piece in the middle)
and this is what i ordered...
http://www.ecstuning.com/Search/Site...94200/ES94200/
#31
07-16-2020 12:54 PM
12-23-2015 10:36 AM
