R50/53 Service Mode Bolts
Service Mode Bolts
Will be doing some work this weekend and was going down to the hardware store to pick up a pair of the m8 x 100 bolts that everyone says to use to get it in service mode.
Does the bolts itself have to be 100 in length? Would it make more room for a m8 x 120 or even 140? The longest bolt they have is a 180.
on
Hi Blane, Welcome to the new scene!
Check out the Stickies at the top of this r53 forum. Basically it's telescoping the front bumper out away from the engine to give you more room to work on it.
Cheers
AlexQS
Cheers
AlexQS
https://www.northamericanmotoring.co...front-end.html
Here is the info!
Here is the info!
Service mode allows you about 4 – 5 inches of space in front of the engine block (and behind the radiator) to enable access to that area. In my case, I needed to have better access to the area where the dipstick guide tube enters the oil pan. I needed to remove the guide tube and take out the broken dipstick stuck inside.
So herewith is my tutorial on how to take off the bumper, bumper carrier, and put the Mini into “service mode”. I put this together by consolidating everything I could find on the various US and UK Mini forums. There were several nice write-ups I found that listed the steps - but none had pictures. In addition, most of them were obviously written by folks who do this all the time, and already know where everything is, etc., whereas it took me a bit of time and patience to locate all of the necessary bolts, etc. I felt that a very basic step-by-step guide, with pictures, would be helpful. I should note that this particular tutorial does not involve removing the wheels - I found that I could access the wheel wells just fine by turning the wheel as far it is would go on each side.
Here are some instructions with photos of using the bolts to slide the radiator out of the way for working room.
http://www.pelicanparts.com/techarti...ant_Change.htm
09R56
11-16-2022 10:49 AM
JPMontes3
08-23-2015 01:26 AM
tippin
08-05-2015 08:43 AM
