I accidentally broke the little nipple off of the tee that is on the far right this hose connects to the black cylinder on the left above the sc pulley then goes down below the throttle body anybody know we're I can get one or can I make it rubber vacuum hose?
I'm going to Monday.. I got my boost gauge working and with a 17% pulley and dt bpv I'm running 16 lbs my mini has 97,000 miles on it does that seem normal
You can run a vacuum line, my stock tube is actually on the floor right next to me :p I broke it a while ago, been running a vacuum line in the meantime. The part number is: 13907515434
I'll vouch for ECS Tuning here and say that they have some of the best prices for OEM parts. Between them and German Auto Parts you should be able to find everything you need.
