R50/53 Torx M10 X 13 Rear Brake
I removed the rear tire because of a knock on every rotation of the wheel and found that the wheel lugs where the only thing holding the disc to the wheel hub.. the TORX that holds the disc to the hub was broken off .. so now the remaining piece needs to be drilled out and replaced.. could someone point me in the right direction as to where I can pick up the Torx M10 X 13 soon? I'm in Canada
here is a picture below
07-16-2020 12:54 PM
aldito2
11-25-2015 09:33 PM
